Go to Post ...I'm still waiting for a Chiefdelph-aholics group to form at the local YMCA. - KelliV [more]
Unread 01-03-2004, 17:57
bludstayne's Avatar
bludstayne bludstayne is offline
bludstayne has a little shameless behaviour in the past
Send a message via AIM to bludstayne Send a message via Yahoo to bludstayne
TTL Ports
I need to know some stuff about the TTL ports on the bot controller:
Does it have a buffer?
Parity?
BCC?
CRC?
Data bits?
Baud?
Stop bits?
Inverted?
I hate signatures. I wouldn't even consider having one.
Unread 01-03-2004, 20:58
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
Re: TTL Ports
All of that can be set in the initialize UART function...Look in the .h files (and in UART.h...it may be USART.h)...There you can find definitions for each option.
Bill
"Those who think that they know everything are especially annoying to those of us who do."
Unread 02-03-2004, 01:52
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
FRC #0254 (The Cheesy Poofs)
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: TTL Ports
For information like this, the PIC18F8520 manual is your best friend.
http://www.microchip.com/download/li...x20/39609b.pdf
Start on page 199 of the pdf (197 in the actual manual).
The Tx and Rx pins of the TTL port are wired directly to the RX2 and TX2 (I'm pretty sure it's USART2) pins on the pic, so you can get all your info from the manual.
Unread 02-03-2004, 16:41
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: TTL Ports
Parity?
BCC?
CRC?
Data bits?
Baud?
Stop bits?
Inverted?
no buffering.
no parity
no BCC
8 or 9 data bits (configurable)
baud:configurable to jsut about anything you want
1 stop bit(i think)
non-inverted.
See the datasheet for the pic18f8520 for more info. Btw the compiler has built in libraries for using the serial port. See the compiler lirbrary reference guide for more info on that. Btw its "USART2".
1139 Alumni
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
TTL pins Dave... Control System 3 07-02-2004 23:59
EduBot and USART ports Dave... Programming 13 01-02-2004 00:02
New Controller Specs Posted Jnadke Programming 58 05-10-2003 08:18
RCU has bad Analog ports - what now? Icebreakers Programming 13 26-03-2003 07:27
