Go to Post instead of complaining, suck it up, think a little harder, and make the most of what you do have. - Andy Grady [more]
Unread 03-02-2004, 02:38 PM
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
How do you turn on the Autonomous mode (to test)?
Hi i can't test autonomous, what i did was put some code in user routines where if a joystick trigger is pressed the autonomouse mode var is set to 0 but when i do it nothing happens????? I can still control the robot!
Team 701
Unread 03-02-2004, 02:39 PM
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: How do you turn on the Autonomous mode (to test)?
set team number to 0000
Unread 03-02-2004, 02:53 PM
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Rookie Year: 1998
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
Go to http://www.innovationfirst.com/FIRST...nout_Guide.PDF
and make yourself a dongle, having a couple of switches to test auton, and to be able to disable the robot when needed are both invaluable, plus if you want to showcase multiple robots, you can change the channel of the radio as well. Highly recommended
Unread 03-02-2004, 08:32 PM
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
This method is the most convinent and safe. It allows you to quickly diable the robot if it goes berserk. (and it will...)
Unread 03-02-2004, 03:01 PM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Normally, you'd be wanting to set the autonomous_mode = 1.
a la,
Code:
autonomous_mode = p1_sw_top;
if (autonomous_mode)
User_Autonomous_Code();
Unread 03-02-2004, 10:33 PM
Thanx mark....(and others also) for the code.... i see what i did wrong ....
I didn't put this in:
I thought that maybe just setting auton = 1 would do the trick i didn't know about that..
Team 701
Unread 03-03-2004, 11:37 PM
JBabbie's Avatar
JBabbie JBabbie is offline
JBabbie is on a distinguished road
you could always copy and paste your code onto the bottom of user_routines.c and put an if statement over it...
if (p1_sw_trig = 1)
run your auto code kinda thing
test autonomous mode CharlieWilken Programming 14 02-20-2004 12:39 AM
inputting data for autonomous mode Lou Programming 2 02-16-2004 10:26 PM
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26 AM
how can you use a gyro in autonomous mode magical hands Programming 3 01-02-2004 01:31 PM
autonomous mode problem on field Chris_C Programming 17 03-26-2003 07:11 PM
