One machine?
We are seeing lots of awesome ideas this year, like have the "ball funnel" from Team 45, but can one robot do it alone again this year?
Believe it or not - The past two years' games could be "underminded" so that only one, dominant robot could win about 90% of the time. I know a lot of you will disagree with me on this one, but it is obvious - just look at Beatty from 2002 and Wildstang from 2003. Both of these teams dominated the game in their respective years, but they still needed a partner to do some basic operations. This year, I believe an alliance will need to consist of two very strong teams if they plan on going a long way in the finals. What do you think? Can one robot dominant this year's game... again? |
Re: One machine?
I agree with you 100% the last 3 years could really be dominated by one robot. This year I believe that the qualifying matches, you will see matches that will be dominated by one robot. However as the elimination matches roll by, no one robot will be able to completely dominate the game. It's just too hard for a robot to do everything at once. Also I believe that there are multiple strategies to win this year, unlike the past 3 years where you saw one main strategy winning (2001: Everything at once, 2002: Goal domination, 2003: Ramp control). It will be very interesting to see how the first week of regionals turns out; from there you will see a lot of teams set their main strategies. |
I think that the obvious answer is a very strong NO - one team will not be able to dominate the playing field by themselves.
I'd even go out on a semi-unrelated limb and say that if you have a non-functional partner, you've pretty much lost the round. Two medocere robots will be able to significantly distrupt a single robot. Just have 1 robot play a little defense by pushing the opponents small balls around the side of the field, and have the other shuffle your balls into their chute, and they pretty much win the game. This game is easy to play defense because unless you store balls internally, scoring is very easy to disrupt, by simply keeping balls in motion around the field. Would you like to try to shuffle balls into the chutes when there's a robot whose sole job can be dedicated to make sure you don't? I know I wouldn't! Just a few thoughts, Matt |
Re: One machine?
As for this year, I do agree - alliances are going to be extremely important. There's just too many things happening on the field. A good strategy executed collectively by all alliance members is key. |
Re: One machine?
I think the last three years have been dominated by teams who had very good strategies coupled with very good robots and were able to pick alliances that complimented them well.
In 2001 Beatty was incredible, but there were other robots that could do what the did. 60, 177, 308 were some of the big ones that did the same thing as beatty. The difference is Beatty picked an alliance that complimented them better than those teams. I think besides having a good robot with a good alliance, sometimes it comes right down to whether or not it's your day. Look at wildstang from last year, they had bad luck at their regionals, but it all came together at nats. One day of good luck can make all the difference. This year there will be a dominant robot, probably more than one. If they get some good allies they can take it. |
Re: One machine?
Re: One machine?
Mr. Flowerday, I would agree with you about your (Wildstang's) position last year at the National Competition. You guys had some great partners, but nonetheless your robot was definitely able to control the field better than anyone else. With your strategy and robot last year, your team was certainly a force to be reckoned with! I believe this year will depend heavily on alliances sharing the work load. Good luck this season! |
Re: One machine?
Personally , if you look at the potential scoring methods, I think the machines that are going to dominate the game this year are those that can consistantly knock the release ball down
and collect and delivery small balls quickly, accuractly and repeatedly there will be 24 small balls on each side of the field, worth a potential 120 points and if you cap the goal, 240 points I havent seen ANY bots in the photo section that capture the small balls - Ive seen plenty with little arms that are intended to push the balls around which is going to be like hearding cats covered in superglue I think the machines that can pick up the balls quickly, move to the corrals, deliver them quickly, and even gather balls from the other side of the field - those are the ones that will win the matchs capping the 2X goal is much simpler than climbing the steps and hanging, so I expect there will be more alliance bots able to cap goals than hang - so the bot that can get those goals filled will consistantly score well over 100 points per match. |
Re: One machine?
If this is not what u ment let me know. |
#10
Re: One machine?
Re: One machine?
Re: One machine?
but I mean capture them from the floor - once a HP shoots and misses, and getting them from the other side of the field if necessary - sweeping them up from the floor and carrying them to the corral, instead of just pushing them around catching the balls as they fall will be an excellent strategy if the release ball is knocked loose by your alliance in auton mode - but it has some weaknesses getting the 24 balls into the goal is going to require keeping both corrals fed with a steady stream of balls, for both HPs, and getting the ones that miss so they can shoot again. besides, out of 950+ teams, only 4 have shown the abilty to gather, carry and control the small balls? thats not many (but then again, we havent posted photos of our bot yet, KateGleasonOne :c) Last edited by KenWittlief : 03-03-2004 at 16:11. |
#13
Re: One machine?
Re: One machine?
Gleeaagh....
We have become jaded and cynical in these past years. We always plan our bot to be able to do it all by itself. As bad as that sounds, we can't ever take the chance of planning on our partner being able to do anything. Year after year, match after match, we get alliance partners who either A. Break down. B. Aren't any good. C. Rookies who have a student coaching and rotate their drivers. Even so, this year we have strategies available for every situation. We can just as easily perform excellently with a good partner to back us up, or go it alone if they can't. |
#15
Re: One machine?
Also you can't predict everythign that is goign to happen, you will always find somethign new either with other bots, or your own. Like i said planning on being by your self is the best way to make your bot. Also student coaches and rookie teams do not mean that that team is bad, just means that they have a fresh perspective on FIRST. Last edited by Tyler Olds : 03-03-2004 at 16:51. |
| Software on more than one machine | PhatalEphekt | Inventor | 4 | 20-01-2004 12:19 |
| which button machine do you use and do you like it? | KenWittlief | General Forum | 10 | 16-10-2003 00:01 |
| machine shop?? | trollin1st | Off-Season Events | 0 | 12-02-2003 21:02 |
| Choosing a machine shop (Re: How important is a machine shop | archiver | 2001 | 9 | 24-06-2002 04:20 |
| The Brazilian Machine on a Fire Truck | Digo | General Forum | 10 | 08-04-2002 01:36 |
