Team 1246 Rookie Bot
How does it look? We're rookies and we only have one mentor, no machine shop, limited funds and a core team of 8 people and yet somehow we pulled this off. Only problem is, the globes are backdriving when we pick up the 2X ball! |
Re: Team 1246 Rookie Bot
It may just be my computer but the picture won't load.
Is there a link or something you could put up? |
Amazing!!!
A very creative and functional robot! I don't think I have ever seen bike tires before, but for this game it coudl be a great idea. Great job guys, I am sure a team at the regional you are goign to can help you out with you globe motor problem. P.S. Iain, the pic works for me. maybe its your computer. Last edited by Tyler Olds : 03-03-2004 at 21:11. Reason: to put in note Iain |
Robot looks good, can't wait to see it in action at the Canadian regionals
Here is what we did (actually, we designed for this, its not really a fix on our bot, its a feature!) Here is a fix: Add about a foot of garage door spring that will be pulling your arm up. You can stretch it as far as you like, but please be careful, seeing as one of thos springs can kill. I put a cable through the middle of ours and anchored it in two non-spring related places so that in the event of a catastrophic spring mount failure, the spring won't do any damage. It is working great for us. |
Looks great, Fady. Can't wait to see it in action!
You guys have done an excellent job with that robot.
It is always difficult the first year and not to downplay the globe issue but if that is your only problem you've done even better being it's your rookie year. I wish your team the best of luck in the competitions. |
#10
Looks great guys! Can't wait to see it in action. As for the globe motors, try switching the Victors into brake mode, changing the sprocket ratio, or you could even (though I would consider this a last resort) put a potentiometer on the arm so that the controller can sense what position it is in, and then write a program that will adjust the power to the motors to achieve a "target" position, measured by the potentiometer. Basically you would be turning the globe motor into a giant servo. What this will do, is as the motors begin backdriving, the potentiometer tells the program "They're getting away!!!
" then the program says "hey where do you think you're going " and gives them a shot of power to bring them back and hold them in the "target" position. The downside to this is that if they are holding a load of a long time, they are basically being stalled at a low voltage, and as a result, the brushes inside heat up, and the motor becomes unhappy . Anyhoo, good luck! ![]() |
#11
EDIT: Ignore this post. I gave an incorrect answer thinking they were using globes for hanging.
#12
- Make it lighter (replace the 30 series extruded aluminum with 20 series) - Use a larger sprocket on the drum (moves slower and more torque) - Add a potentiometer to measure position of the arm - Add a tensioner (sp?) for the belt - Some programming modifications to improve control We already have full position control of the opening and closing of the arm. We can stop the piston of the cylinder at any position. We should have similar control of the drum of the arm with the modifications. |
| Am I the only person with this job? | A. Leese | General Forum | 55 | 22-06-2006 20:10 |
| Real names, please | Andy Baker | General Forum | 131 | 21-07-2004 22:07 |
| Helping out a rookie team | trollin1st | General Forum | 0 | 19-10-2002 22:59 |
| TEAM 121 and a rookie team on CBS SAT MORNING! | Joe Menassa | General Forum | 7 | 21-03-2002 00:47 |
