Go to Post IMHO, [the driver's] job is to drive the robot. The coaches job is to monitor everything in a match that isn't your robot. - CalTran [more]
Unread 04-03-2004, 10:17
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Exclamation Code for the Dashboard
We are having a problem with seeing all of the dashboard program that we downloaded. So my team has desided that i should just write one in Visual Basic with only the things that we need. Can anyone tell me where i can find the code for the Dashboard download so that i can change it???? I would be eternally gratefull. Thanks!!!!!!!!!
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
Dashboard Decoder Demo Program Source Code Now Available archiver 2000 0 23-06-2002 23:11
