Go to Post If you find yourself extremely upset, frustrated, angry, or any other term of emotion, please stop and ask yourself why you participate in FIRST. - indieFan [more]
Unread 21-03-2004, 16:33
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: High Scores
In Detroit this weekend the high points was 135 and the highest QP was 85. They were not in the same match.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 22-03-2004, 08:10
Dr.Bot
Posts: n/a
How to beat 210
You need two ball handlers that can hang, plus maybe a specialty robot that can get one or two of the 10 point bonus balls, or steal 5 pt balls from the opponents.
Step one
Both robots go fo mobile goals, bring them over and uncap - hopefully not triggering opponent bonus -1 robot positions mobile goal under oponent ball drop and defends. (A good programable autonomous mode to block out opponents)
Step two
Gather balls ( maybe bonus balls get to human player. Get ten balls into stationary goal, 4 or more into mobile goal (perhaps a yellow or two, cap
both goals at the 30 second left mark.(140) Good herding ability, shooters.
Step three: get two robots hanging.(100) Hard to hang if being pushed.
Total score 240+.
Will we see a 240 at the Nationals - I think so. Will there be a 300 - probably not. There are not enough big ball handlers that can hang. I've only seen 1 10pt ball scored.
Unread 22-03-2004, 12:43
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Re: High Scores
130 was our high qualifying score, WITH NO HANGERS. We scored small balls and doubled. I wanted to know if anyone beat that with out a hanger yet.
Unread 07-04-2004, 21:04
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Re: High Scores
I believe there was a 210 at the Midwest regional
Unread 08-04-2004, 00:45
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: High Scores
- The most points SCORED during Autonomous Mode?
It isn't possible to score points in autonomous! Even if you hang during autonomous, you have to be hanging at the end of the match, so you haven't actually scored until you remain hanging at the end. And your human player can't put any small balls into the goals.
OH!!!!....I just realized that you can score in autonomous! By moving a mobile goal under the ball drop and having the balls drop in.
See you in DC!
Unread 08-04-2004, 10:52
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: High Scores
Originally Posted by tkwetzel
It isn't possible to score points in autonomous! [...]
Exactly! Although I do now realize that the max theoretical score during autonomous will probably about 10 or so (or whatever is the capacity of the rolling goal that didn't bounce out from the momentum of the dropping balls). You can't be in two places at once, though you COULD drag it over the the OTHER drop by sec 45.
Unless of course someone had some SUPER way to collect the dump AND "conveyor" it into the static goal... But I haven't seen ANY robots this year that attempted THAT insanity. You need weight allowance for your bar method so why waste it on a conveyor method that could dump it to the floor. It's much better to INSURE the score with manual control than take ANY chance of that happening.
Scoring during autonomous is TOUGH to do. You'd have to hitch, uncap, drag it under, THEN either run over to the tee, or your PARTNER has to trigger the tee. This must be sequenced properly, and all in under 15 seconds. That takes a partner that can control WHEN they trigger. Did ANYONE manage to do that? If so, you probably have THAT record.
(That also brings up the undefined problem of either communicating between two random robots, or setting timers properly between two EXCELLENT performing autonomous modes...) Now we DID manage to get under, spread, and collect balls during autonomous, but we didn't score them... I'd have to go back and see if anyone remembers how many we collected.
I'm also curious though if ANY team managed to get a ball hopper under the OPPONENT'S chute during autonomous and collect THEIR ball drop, so I'll also propose these high score records:
- The most balls collected from OPPONENT'S drop during autonomous mode.
- The most collected from one drop (at any time).
- The most TOTAL balls DROP collected in one rolling goal (includes autonomous drop, AND opponent's at sec 45, or vice versa).
Did anyone get ALL 18 balls into their robot bin from the drop? Our robot (Team 1015) caught 13 balls twice at 45 sec so we'll toss that out there as the "score to beat". I *think* we also got one or two during autonomous (we weren't QUITE in position when it was triggered) but I'll have to verify if we got any at all.
Any takers on ANY of the other "high score" records I'm proposing, even if it's only ONE ball?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 08-04-2004, 00:46
Dennis Jenks Dennis Jenks is offline
It's good to be home.
FRC #0254
Rookie Year: 1999
Dennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud of
Re: High Scores
Ok, I know there are some awesome teams out there, so I'm curious, who else has hit 200 on multiple ocasions this season?
Dennis Jenks
FIRST Team 254 Mentor
Unread 14-03-2004, 20:57
RoteAugen's Avatar
RoteAugen RoteAugen is offline
None #0138 (Entropy)
RoteAugen will become famous soon enough
Send a message via AIM to RoteAugen
Re: High Scores
Originally Posted by teno121
140-145 at BAE with teams... 40, 138, 213, and 319 I think.
yeeeaahh team 138!!
Saber pride baby
it really sucks that Trinity (team#40) is in the same boat as 61 (not enough money to go to nats)
if any of them are readin this: You have one helluva bot right there. keep on truckin
Unread 07-03-2004, 11:15
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Re: High Scores
Originally Posted by tb222
What are the highest scores this year? Watching the VCU webcast, and the highest there is only 130. Theoretically, the highest possible winning score would be 380/375. (This would give you a win and the 375 ranking pts.) I'm sorta dissapionted that teams are struggling to break 100. I think human players need some more practice shootin' hoops.
I believe the highest score I saw at Manchvegas was about 150. I did miss a few matches whilst preparing to be human player, but I'm fairly sure no one went much higher than that.
On Thursday, during the practice rounds, an alliance of us (Team 1073) and Team Hyper 69 scored well over 200 points during the 2 minute limit. Our robot herded an ungodly amount of balls (it can do four at a time very well) to me and Joe (the hyper human player), and we filled up the stationary goal. That was capped by Hyper. They then hung. Joe and I then proceeded to fill up the mobile goal. Though there was no official tally, I counted the number of balls roughly and the final score was over 200 points.
Man, we were a good alliance. Unfortunately, they were seeded second, and we were seeded ninth, and when 501 (1st seed) picked Hyper, we were bumped up, and therefore unable to be chosen. Hyper's robot played in all of the finals matches and the alliance of Hyper, The Power Knights, and Team 176 eventually won Manchvegas.
But yeah...that was the highest I've seen so far...
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 14-03-2004, 20:22
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Re: High Scores
the first final match @ UCF regional had a tie... and i think that was the highest tie scored this year so far... 120 - 120... 4 robots hanging from the bar and 4 balls in each stationary goal... that was a mad awesome match to see...
Unread 14-03-2004, 21:05
Allison K's Avatar
Allison K Allison K is online now
AKA: Allison Kneisler
FRC #3538 (Avondale RoboJackets)
Allison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond repute
Re: High Scores
The highest match I saw was 165 - 60 with 494 (martians) on the winning side and my team (226- TEC CReW) on the losing side. I can't remember the other two teams in that match. the other high one I saw was 120 - 120 in the elimination rounds. The lowest I saw was 10-0 with my team on the winning side. All this at GLR.
Allison
FRC3538 : RoboJackets : 2014-??? : Head Coach & Drive Coach
FRC226 : Hammerheads : 2003-2013 : Strategist
Unread 14-03-2004, 22:42
Will Hanashiro Will Hanashiro is offline
GM/Kettering Mentor
FRC #0322 (F.I.R.E)
Rookie Year: 1999
Will Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really nice
Send a message via AIM to Will Hanashiro
Re: High Scores
Allison
team 322 was paired with 494 in this match...
West Michigan Regional #1 Seed
2006 GLR Motorola Quality Award
2006 WMR GM Industrial Design Award
Kettering University ME Class of 2009
Unread 14-03-2004, 22:50
Crash852 Crash852 is offline
Member
FRC #0492
Team Role: Student
Crash852 is on a distinguished road
Re: High Scores
Allison
Team 492 scored 170 points in one match with Team 1031 , which was tied for highest scoring match at the Pacific NW Regional. See, our team is only two teams older than Team 494, and we both scored the highest points at our respective regionals!!
Ok, i am REALLY lame.
Unread 14-03-2004, 23:15
RMiller RMiller is offline
Taking a Year Off
AKA: Ryan Miller
RMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really nice
Re: High Scores
The highest qualification score at STL was 145-70 with 1272 and 650 beating 939 and 1182. However throughout the finals at least half the scores involved one or two alliances above 100. All but the first match out of four in the finals saw both alliances above 100 points (80-80, 130-120, 135-140, 135-110).
  #15   Spotlight this post!
Unread 22-03-2004, 23:25
Meandmyself's Avatar
Meandmyself Meandmyself is offline
Registered Magic Programming User
AKA: Gordon
#1123 (AIM robotics Crimson Lightning)
Meandmyself will become famous soon enough
Re: High Scores
Highest score at Annapolis this past weekend was over 200. They made an announcement about how this was the highest scoring one in the nation so far. I don't remember exactly what the score was, but both the stationary and mobile goals were capped and both bots were hanging.
They call me the Idea man.
Not because my ideas work,
But because I have ideas...
I'm not a programmer. I'm an electrical guy who can program. If only I understood C!
www.aim-robotics.org //team website
www.tjhsst.edu/~gburgett //cool stuff for school
robotics trivia kewlkid382 Chit-Chat 63 16-03-2004 09:50
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
Sacramento Regionals Hermione692 Regional Competitions 57 03-04-2003 02:29
Thanks Buzz and Aces High P.J. Baker Thanks and/or Congrats 2 18-03-2003 12:59
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
