Go to Post Students design and build it, the engineers/mentors are there to guide us when we stray off the path. A great way to learn, a great way to mentor, a great way to grow. - chellyzee93 [more]
Unread 08-03-2004, 19:04
bd02's Avatar
bd02 bd02 is offline
752-KoF Programming Guy
AKA: Jose Santiago
#0752 (Knights of Fury)
bd02 is an unknown quantity at this point
Send a message via AIM to bd02 Send a message via Yahoo to bd02
Exclamation problem with autonomous that has stumped all programmers so far
The autonomous mode i programmed for our robot for dead wreckoning was working fine. It would count the # of 26.2 ms and use them to time the movements of the bot. The first time i setup the code with sample times it worked just fine, but once i put actual times in that we received from out test runs, the cpu seemed to skip the first few steps and and go directly to the area where the robot is todl to move forward for 3 seconds. I asked a group of programmers at the Regional in Trenton, which were mostly coaches or people with enough knowledge of the language to comprehend my code, and they all said my code was written fine and should be working ok. I myself do web programming the usual html (even though it isn't really considered a language), vbscript, javascript, asp, sql, and php, and have had no real trouble in the past with debugging, but now I'm just stuck. Can anyone help me with this?
Attatched is my working code. Whenever i changed the time values for each state or change SECS_TO_TICKS to MSECS_TO_TICKS, it throws it off for some reason and makes it skip states. Any ideas?
PWM problem in autonomous outofcontrol Programming 5 27-02-2004 11:58
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
autonomous..... Arefin Bari Rumor Mill 30 19-12-2003 10:53
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
