Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Unread 09-03-2004, 09:27
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Exclamation HHEEEEEEEEEEEEELLLLLLLLLLPPPPPPPPP!
When I build my project where does it put the files that it makes??? I know that it sounds kinda lame but my team program leader is home sick and i need help. Thanks!
Unread 09-03-2004, 09:33
WebWader125
Posts: n/a
Re: HHEEEEEEEEEEEEELLLLLLLLLLPPPPPPPPP!
The output files (FrcCode.hex being the most important) should end up in the same directory as all your source files. When you execute the IFI Loader, click on the Browse button to locate and select FrcCode.hex.
Actually, if the computer you're using has been used to load the code before, the Browse button on the IFI Loader should probably already default to the correct location.
Unread 09-03-2004, 09:47
Lightbulb Re: HHEEEEEEEEEEEEELLLLLLLLLLPPPPPPPPP!
Thank you very much!
Unread 09-03-2004, 10:36
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Just an additional note.
Some programmers do override the MPLAB default of the project directory and put the hex files in a separate location.
You can check in MPLAB Project->Build Options...->Project
at the top of the "General" tab under "Output Directory"
If it's blank then the default project directory is being used, otherwise, it will have a directory path where the hex file is deposited.
Unread 09-03-2004, 14:05
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Another note: the hex file will have the same name as the project file (*.mcp).
