Go to Post We may be changing cheese heads for cheesy poofs, but in the imortal words of Gen. MacArthur "we shall return" (team # 2437) - cdebo [more]
Unread 03-10-2004, 08:31 PM
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 222 3 speed closeup/cutaway
Unread 03-10-2004, 08:36 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: pic: 222 3 speed closeup/cutaway
Sweet looking tranny. I like the idea, it's nice and simple. I'm just curious if you guys have any bearing surface between the free spinning gears and the output shaft. Is it just steel on steel with lots of lube, or is there a bronze bushing in there?
Also, how do you guys index it so that shifting rod only moves part way?
Other than that, it's a really awesome, simple idea.
Unread 03-10-2004, 08:42 PM
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
I agree that it is a sweet tranny and an amazing idea, but is it really that simple? The concept might seem simple, but the production seems very difficult. Kudos to team 222 for doing it though.
Also, are those trannies powered only by the CIM motors?
See you in DC!
Unread 03-10-2004, 08:57 PM
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
Yes the shaft and gears are steel on steel. Both of which I think are heat treated. We also used some kind of spray on lubricant that sticks to the gears.
If you look on the other pictures there are shifting stops to keep it from shifting too far.
Since this is our first year ever building a tranny we went overboard. The production could be simplified greatly. There are lots of different things we could modify such as the side plates and the whole shifting mechanism could be redesigned!
Once I finish the inventor award (due 3/15) I hope to find time to make a white paper and redesign it!
thanks for the comments
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 03-10-2004, 09:07 PM
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
I'm looking foward to seeing a white paper on this beautiful tranny.
See you in DC!
Unread 03-10-2004, 09:18 PM
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
I hate to say this because I think I am only adding fuel to the fire* but... ...I like it!
The part I like best is your method of transfering the torque via the balls. Very elegant.
Nice job.
Joe J.
*I have discussed in many posts that I question whether all this shift on the fly mania (yes, I say mania) is worth the bother when you consider that you can make a relatively robust transmission shifter with a standard drill gearbox and servo.
The only thing that has me thinking is Jim Zondag's 4 speed with automatic shifting (and I suppose your 3 speed would work about as well). Perhaps there is a game where such things make sense. I am still pretty much for simplifying things, but perhaps I was too hasty to close my mind. Time will tell...
Unread 03-15-2004, 10:29 PM
dan 322's Avatar
dan 322 dan 322 is offline
The FIRE team
AKA: Dan Clemons
FRC #0322 (The Fire Team)
Rookie Year: 2000
dan 322 will become famous soon enoughdan 322 will become famous soon enough
Nice job.
Joe J.
Awesome design, but I have to agree with Joe.......seems like the simplest & most robust robot always wins. We had an awesome 3 speed planetary gear, shift on the fly tranny two years ago. Debug period was horrible, but once we got it fixed it was great. I just hate wasting a regional to debugg. ROBUST, ROBUST and ROBUST if you want to win. If not, at least have a lot spared parts pre-made and assembled for quick change.
2001 Kettering Kickoff Champs
2002 Western Michigan Finalist
2002 Kettering Kickoff Champs
2003 Pittsburg Regional Champs
2003 Great Lakes Regional Finalist
2004 Great Lakes Regional Champs
2004 Website Award Winners
2004 Newton Division Finalist
2005 Great Lakes Regional Finalist
2005 Motorola Quality Award
2006 Motorola Quality Award
2006 General Motors Industrial Award
Unread 03-15-2004, 10:40 PM
henryBsick's Avatar
henryBsick henryBsick is online now
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
We thought of this and tried them out. I am not kidding when i say that i ran it until the motors were burning hot then waited untill they cooled and again and again shifting a ton to break them in. They never missed a shift. Plus all of the auton we tested. Wow, all the late nights were on the auton and drive practice. We ran in it a lot in the few days we got and it did perfectly. I think it will cary us through the season and mini's prety well.
-Henry
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 03-15-2004, 11:17 PM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I still can't really picture the "plunger" type deal that slides within this shaft and pushes the balls out. Can I get a real or Inventor picture of that? Thanks. Also, I don't get how when the "ball pusher outer" is not under the ball, how does the ball not just fall into the shaft. Sorry for my less than technical terminology.
Unread 03-16-2004, 11:00 AM
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
I too would love to see a more detailed drawing of the inner slider that pushes the balls up.
It seems that it should be possible to design this slider so that there is a neutral in between each gear, where all the balls are retracted. This would make it easier to synchronize the rpm of the input and output shaft for smooth shifts, as described in my earlier post.
It should also be possible to design an electromechanical, sequential shifter using an electric solenoid. This would likely be lighter and faster than a pneumatic shifter. I'll see if I can some up with something.
Unread 03-16-2004, 11:12 AM
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
With our pneumatics, we can only go all the way out all the way in or no air presssure and ram the wedge at a 90 degree angle to push the the cylinder into 2nd. It only gives us three postitions, therefore eleminating the possibility of a neutral. If we used other methods like a lead screw or what you atre describing, yes, we could have neutral position. Our original plan was for a leadscrew and a pto actuall, we scrapped it to geta faster lighter shifter.
Brad will post an inventor soon I think.
Thanks for the comments, questions, and suggestions. We are always eager to answer more.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 03-10-2004, 09:10 PM
Rookie Year: 1998
In that case, for your redesign I'd suggest a bronze bushing or some such between those free running gears and the shaft. I just got lectured by my design prof about galling, and it wasn't pretty. Apparently, two very similar metals have a tendency to stick together. Thus, if your lube ever gives out, the gears will sieze and bad things will happen. so as a corollary, check the lubrication whenever you get a chance, just in case.
Unread 03-10-2004, 09:23 PM
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
As you can somewhat tell, the word, well, name "FRED" is on the inside of the tranny. I just noticed it myself but, I believe it is there because he is NOTORIOUS for greasing, greasing, and well, greasing. We should be ok and he should have some fun this year, but thanks for the heads up.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 03-11-2004, 08:31 AM
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
This is certainly a nice, compact design. Reminds me of my dual range Suzuki I had in the late '70's. I have looked at how to easily do the machining and am very interested in seeing your white paper.
As for the lube. We are lucky that we run short matches and that the total life of our robots is measured in hours. Greasing on a regular basis allows us to run on the edge with our designs. I do agree with Kevin's professor provided this was on production equipment. The Suzuki I had (actually I still have the motor and gearbox) was steel on steel but ran in an oil bath.
Andy Brockway
Team 716, The Who'sCTEKS
  #15   Spotlight this post!
Unread 03-11-2004, 11:47 AM
Rookie Year: 1998
Speaking of Kevin....
I just had a test today in that class, and it reminded me that the issue is worst if the metals are of the same or similar composition, same hardness, and relatively low hardness. The threshold for same hardness is within 5 HRC of each other. Soooo.. if you have a hardened steel shaft there, and the inside of your gear isn't hardened you should be reasonably ok.
Also, I'd still be concerned even though this isn't production equipment. Our prof showed us a few examples of some coupling threads that suffered from galling, and that's obviously not a high-cycle kind of thing. so mostly, I'd just keep it lubed and keep these things in mind in your white paper.
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 04-23-2004 01:51 AM
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 03-11-2004 09:39 PM
pic: dual speed gearbox CD47-Bot Extra Discussion 9 10-07-2003 03:04 PM
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 03:51 PM
