Go to Post Every robot needs a locky-thingy. A robot without one might fire when it isn't supposed to, and hit the wrong target; e.g., a referee, FTA, or robot inspector. - Richard Wallace [more]
Unread 10-03-2004, 22:03
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Rookie Year: 1999
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
quick question: TIMERS
The code below works but i need just a few more loops in the code in order to get it to go exactly where i need it to any one know how i can make it start a new count after it gets past 254 so it doesnt loop, and i can add a few more steps to it, or does some one have a better way of doing this ? I got this way to work it just needs to run for a little bit longer.
Code:
void User_Autonomous_Code(void)
 int count;
 count = 1;
 while (autonomous_mode)   /* DO NOT CHANGE! */
     if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
         Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
   /*40ticks = 1 sec 20ticks = .5 secs 10ticks=.25 secs */ //increse counter by 1 /* DO NOT DELETE, or you will get no PWM outputs! *//*40ticks = 1 sec 20ticks = .5 secs 10ticks=.25 secs */
   if ( count >= 124 ) {
   if (count > 0 && count < 34 )
    pwm05 = 60;
   if (count > 35 )
    pwm05 = 127;
   if (count > 0 && count < 30 )
    pwm04 = 0;
   if (count > 32 )
    pwm04 = 127;
   if (count > 35 && count < 90 )
    pwm01 = 190;
    pwm02 = 190;
   if (count > 92  && count <= 122)
    pwm01 = 190;
    pwm02 = 53;
   if (count > 130 && count < 160 )
    pwm01 = 190;
    pwm02 = 190;
   if (count > 163  && count <= 183)
    pwm01 = 190;
    pwm02 = 53;
   if (count > 223 && count < 250 )
    pwm01 = 190;
    pwm02 = 190;
   if (count > 255  && count <= 275)
    pwm01 = 190;
    pwm02 = 53;
   ++count;
      Putdata(&txdata);
any help would be greatly appreciated.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Quick Question Burgabot Programming 31 02-12-2003 19:22
Quick <hr> question Jack Website Design/Showcase 1 31-01-2003 22:19
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
quick question about qualifying points Hymnson General Forum 4 25-09-2001 21:19
Quick Question, i guess Andrew Rudolph Motors 1 12-08-2001 14:39
