Go to Post How many FIRSTers would quit if they found it was bad for them? I think most FIRSTaholics are thirteen steppers ;) - phrontist [more]
Unread 11-03-2004, 18:03
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Painting Aluminum
For materials such as the diamond plate used on the side of the platforms this year, what would be the best way to spray-paint them so that they maintain the same reflection from the aluminum but still has color to it? Basically, a tinted clear coat. I couldn't find anything relevant online. Yet.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 11-03-2004, 18:12
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: Painting Aluminum
I'm not sure how well this would work on aluminum or steel, but at the TechnoKat shop last year we had a spray paint that could be used to paint clear glass. We had colors like green and red, and when sprayed on the glass it would color the class, yet keep it transparent at the same time. I remember playing with this a little bit and if you can find it and mess around with some it might stick to metal.
Purdue Alumni
Cummins, Inc.
Unread 11-03-2004, 18:17
Jay5780 Jay5780 is offline
no team (Aztechs)
Rookie Year: 1996
Jay5780 will become famous soon enoughJay5780 will become famous soon enough
what your looking for it a process called anodizing. I've had friens who have head paintball markers done like this. Check a local paintball proshop and maybe they will donate the work. It can be expensive and you need special equipment to do it yourself.
Hope this helps
Jay
Unread 11-03-2004, 19:04
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Anodizing would make the surface less "shiny". Anodizing itself does not color parts, but is used to protect aluminum by making it's surface harder (puts a coat of aluminum oxide on). Color can be added because anodized aluminum is more porous then normal Al (which is also why it loses some of its reflective properties). [Someone correct me if anything I said above is wrong].
You don’t need special equipment to anodize aluminum, but it involves a strong acid (the sulfuric acid that’s in your car battery would work) so it needs to be done by someone with experience (sort of like welding).
Yan, I think spray paint leaves an ok finish, isn't that what was used on last year's robot?
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 11-03-2004, 19:24
no team (Aztechs)
Rookie Year: 1996
Greg
Your right that the process itself does not color the metal however check this link out anodizing benifits the key section to read is Aesthetics. Aesthetics. Anodizing offers a large increasing number of gloss and color alternatives and minimizes or eliminates color variations. Unlike other finishes, anodizing allows the aluminum to maintain its metallic appearance.
At least with anodizing you get the metallic look unlike gloss paint that will hide the textures of the surface plus paint chips anodized colors do not.
Hope this helps
Jay
Unread 11-03-2004, 22:57
For anyone that's interested:
You ever notice how if you cut or scratch a old piece of aluminum the exposed surface is much more shiny then they outside. This is because the outside has oxidized to form Aluminum Oxide (Al2O3). This happens just like rust forms on iron. Anodizing produces a thicker layer of Aluminum Oxide faster then it would otherwise happen.
Because of this I don't think anodized aluminum is as shiny as it is before it was anodized. Jay pointed out a great link describing the advantages of anodizing.
Personally, I think anodized aluminum looks better. Knowing Yan and his situation, I doubt he wants to try and anodize his aluminum part (well, he probably does but it most likely wont happen ). I would suggest cleaning the aluminum with rubbing alcohol then applying a coat or two of normal spray paint. It probably won't be the most durable finish, but it's cheaper then anodizing.
Greg
[If I’m wrong correct me]
Edit:
Here is a good link about the process of anodizing aluminum: http://www.focuser.com/atm/anodize/anodize99.html
He makes a few mistakes (mistakes a base for an acid!) but by FAR the best anodizing description I could find.
Unread 11-03-2004, 23:07
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
Team Role: Mechanical
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
im not sure if this would work on aluminum but powder coating provides a nice transparent coat of color while keeping the metalic properties of the metal
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 12-03-2004, 00:00
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
Powder coating can add a lot of weight though.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 12-03-2004, 00:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Last time I saw a powdercoated robot, it wasnt transparent. It completely coats the surface with the powder, and you sure cant see through it.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 12-03-2004, 01:30
phrozen solyd's Avatar
phrozen solyd phrozen solyd is offline
AKA: Adrian Santos
Team Role: Leadership
phrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nice
Send a message via AIM to phrozen solyd
http://team254.bcp.org/index.php?men...&vars=numID_23
The red and blue parts of the lower frame, subframe, and upper arm assembly are all powdercoated.
Another point of interest - the silver claw section is nickel-plated, giving it that chrome effect. Nickel plating is a form of anodizing.
- Adrian Santos
Team 254, the Cheesy Poofs
Unread 12-03-2004, 14:44
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
GregT:
It depends on what process you use to get it done. There isn't just one way to anodize everything different processes still the same anodizing effect with aluminum but leave certain characteristics or features that other will not. Organic Dying if you scroll down to were it says organic dying and look under Appearance of surface it says that the Metallic character of the aluminum retained high brilliance. so there are ways to have something anodized and still retain the metallic shine it once had.
Unread 12-03-2004, 18:11
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
I don't really know much about anodizing, but if you decide to paint it, I can offer you some help.
You can't just spraypaint metal. If you do, you'll find that it begins to flake off after some time (a week, two... depends on how much contact the material has). This happens because the metal doesn't really bond all that well to the paint molecules. If you want to paint metal, you first need a primer.
A primer essentially makes the metal a lot more pourous so that the paint molecules bond to it better. However, just like paint, you should sand the metal before applying the primer. Some people say you should sand the primer using fine grit sandpaper and apply a second coat before you apply the paint. You can get primer at home depot or any automotive store (Pep Boys, etc.)
With the paint, you should do atleast two coats, three coats. People recommend you again sand using fine grit sandpaper in between coats. When using spraypaint, the important thing is to do a cross-hatch pattern -- a 'coat' consists of a very light spraying in vertical lines and very light spraying in horizontal lines afterwards. Don't use too much, though - you get terrible results if you add too much paint in one coat. The end product comes out a lot better if you use too little paint on a coat but do several coats than if you add too much paint on one coat.
Finally, to get that shiny automotive-metalic effect, you need to buy clear-coat spray. This is exactly what it sounds like - a clear coating of paint. Its this stuff that adds the shininess to your paint job and makes it look like a car.
The biggest drawback to spraypainting is the time it takes to get a good job. With atleast one coat of primer, two-three coats of paint, and a layer of clear-coat, the whole process can easily go over a day (you need to give a few hours for the paint to dry in between coats).
I learned about all this from case-modding sites (some people are crazy enough to make their computers look like ferraris ;-) ). If you want more details, go to sites like Virtual-Hideout or Bit-Tech and search their forums for "painting guide"
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 11-03-2004, 19:20
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
when you add color most or all the Metallic character of the aluminum lost because pigments cover the underlying surface. but if you get just a clear coat no pigment Metallic characters of the aluminum are retained. or Organic Dying you actually all Metallic character of the aluminum retained adds a high brilliance. so it is possible to keep the same brilliance of an object that is anodized
im no were near this smart i got all my information off www.anodizing.org great site with anything you would want to know about the process actually some what interesting.
Save time? Use aluminum extrusion kits! Tim Skloss Technical Discussion 36 03-02-2004 10:38
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Bosch Aluminum Structural Framing Carl Owenby Technical Discussion 37 15-01-2003 21:11
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
