Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 11-03-2004, 20:37
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
Differences programming ADXRS150EBs to BEI Gyrochips?
Hi, ;
first off......thanks to everyone that helped me w/ the whole gyro ;
situation...esp. Ken Wietcliffe thanks for sticking around on the thread ;
answering my questions.;
Now i have one more... I have finally programmed a test bot to work with the;
BEI gyrochip... we have finally found and ordered the ADXRS150EB chip but ;
we probably will only have hours to assemble it etc. and program it...;
my question is : are there any differnces between programming the two ;
different gyros...i wouldn't expect any, but i heard that the ADXRS150EB ;
outputs at 40hz or something and that during user_routines_fast it maybe ;
too slow and therefore it would not be precise enought (as the program ;
would loop several times adding the same value);
I'm very confused as to how it may not work but i'm just making sure;
Thank You ......;
Salik Team 701
error line #15 : syntax error
Team 701
