Go to Post From past experience members of our team insist on never trusting gravity. - Vash [more]
Unread 12-03-2004, 20:28
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
What do you do during autonomous mode?
What do you do during autonomous mode and how?
We (team 701) will drive forward extend our arm turn 90 degrees and drive back to grab the goal, the extended arm drops the 10pt ball then we drive back (w/ goal ) as far back as possible.
To do this we use IR wheel counters to measure distance and to calculate angle we use a gyro... to measure the angle of the arm we have potentiometer ....
Team 701
setting autonomous mode Allison Programming 10 08-03-2004 20:37
test autonomous mode CharlieWilken Programming 14 20-02-2004 00:39
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
