Go to Post Plot twist: I'm actually Dean Kamen, and I've seen so many water game suggestions that we're now considering it. :deadhorse: - Derpancakes [more]
Unread 14-03-2004, 19:32
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
QBASIC, Parallel Ports, and Windows XP
For a little piece of technology I am building, I am having a computer control a motor assembly. The computer, running Windows XP, is using the parallel port and QBASIC to control a buffer (7407), which is controlling a transistor. Under Windows XP, the parallel port takes several seconds to change the status of the parallel port, if it even successfully changes it at all. Many attempts fail with no reason given, and those which do succeed take up to 20 seconds to change the parallel port's output.
Does anybody know why this is happening and how I might be able to overcome this problem? Allocating an IRQ to the parallel port has not fixed anything.
As a side note, the parallel port on my machine outputs 3.2 Volts when it is high, and roughly a .5 volts when low. I have checked other computers, many of which output roughly 5 volts on high and ~0.1 volts at low. I would try another machine, but this one is a laptop.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
