Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 14-03-2004, 22:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Operator Interface LED Drivers
Has anyone programmed the OI LED drivers in the new RC?
In the old OI/RC combo, the LED drivers were tied to outputs 12, 13, 14, and 15. Despite the documentation saying that pwm1_red, etc. are the output drivers, those drivers are only tied to the blinking lights on the OI itself and do not drive the four drivers available on ports 2 & 4.
If anyone has figured this out for the new RC, I would appreciate knowing what variable connects to these drivers.
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
LED colors archiver 2001 1 24-06-2002 00:04
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
