Go to Post It only takes micro-seconds to release the magic smoke and empty the teams' budget. - Jim E [more]
Unread 15-03-2004, 22:01
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Warning! Check the screws on your Maxi fuse block!
While working on our second robot we noticed a problem with our Maxi fuse block. It seems that the metal connectors are held to the plastic block only by a single screw on the underside. We've found that these can loosen and cause problems. Make sure that your connectors are screwed in tightly enough!
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
pic: 40-Amp Fuse Block CD47-Bot Robot Showcase 7 20-02-2004 00:23
Maxi 40 Amp Fuse Panel mtrawls Electrical 25 13-02-2004 15:19
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
