Go to Post Do not treat Vex and FLL as inferior because they may not get as much exposure as FRC on these boards. Just remember, FLL has seven times more teams than FRC from twenty additional countries. - artdutra04 [more]
Unread 17-03-2004, 15:41
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Anyone with a replacement Printf?
I wrote a buffered i/o system for the IFI controller. It is file oriented so output can be directed to either the program port or the TTY port. It is buffered so calls to printf can occur even in interrupt handlers (no blocking) It can handle the actual i/o either as polled in the fast loop, or via a low interrupts. I'll be publishing it soon. I have fputc() fgetc(), etc. done.
The problem is that the existing IFI printf library doesn't exactly lend itself to creating an fprintf() routine, and a "printf()" on top of that (i.e. default output to one or the other ports).
Maybe I just need a primer on how printf(...) works... But I thought I would ask and see if someone has a version that would be more amenable to the streams approach to output.
The original goal was to have the debug menu on one port and still have access to another port for serial peripherals (say, a GPS unit?) But just having it buffered and polling makes a HUGE difference in performance and ability to debug with printf statements.
Unread 17-03-2004, 15:46
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Anyone with a replacement Printf?
Here:
Originally Posted by Mark McLeod
I just put some routines here http://www.chiefdelphi.com/forums/showthread.php?t=26529 that do this.
You can just call the one routine that prints decimals without changing any of your own printfs.
PS- why do you have to have at least 2 characters?
Unread 17-03-2004, 16:58
The modified printf's referenced, above, don't help me. They just fix some of the more blatent errors in IFI's code.
Unread 17-03-2004, 17:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Since the system is relativly limited, streams don't do much good, as their whole point is to allow you to work with multiple devices in a similar fashion. If your thinking of writing printf over from scratch, I'll warn you that it is very hard to work with variable parameter lists in C. I, personally, would hate to have to do it.
Unread 17-03-2004, 17:49
Crazy_Ed's Avatar
Crazy_Ed Crazy_Ed is offline
Amature Progammer
AKA: Ed Orsi
#0710 (PAW)
Crazy_Ed has a little shameless behaviour in the past
Send a message via AIM to Crazy_Ed
I don't know enough to answer your question, but I would just like to comment that serial ports are way to slow to send anything major across. Maybe next year we get usb or *gasp* ethernet.
I came, I programmed, I tore my hair out.
Unread 19-03-2004, 02:20
Ok, I finally figured out how to modify printf_lib to do what I want. I have posted a white paper + code out my teams web site in the white papers section.
http://www.titanrobotics.net/index2....whitepages.cfm
It is a fully buffered I/O for both the TTY and Program serial ports (i.e. streams).
It is rather nice to be able to have the user interface (to examine the health of the robot) on one port and have the diagnostics spit out on another port simutaneously.
It is also really nice to be able to put printf() in interrupt handlers and have it work without messing up the interrupt handler.
Enjoy.
printf and newlines Jeff McCune Programming 5 21-02-2004 21:09
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
printf isn't printf-ing. Help! Meandmyself Programming 14 15-02-2004 16:27
clear printf box? telefragger2000 Programming 6 05-02-2004 17:40
Help! Need replacement Fisher-Price Motor/Gearbox Mr. Van Motors 2 13-02-2003 07:35
