Go to Post Purpose over pimpness is a policy that we are trying to adhere to. - santosh [more]
  #16   Spotlight this post!
Unread 17-03-2004, 21:18
AsimC AsimC is offline
#0871 (West Islip Robotechs)
AsimC will become famous soon enough
Re: Help! Programming question with triggers
startup meaning when i turn the robot on?.... nope they dont move
WEST ISLIP ROBOTECHS - Team 871
-2004 SBPLI REGIONAL CHAIRMANS AWARD WINNERS!
-2003 SBPLI Regional Finalists with 545 and 566
-2002 SBPLI Rookie All-Star
-Former Student Team Leader and Programming Head
  #17   Spotlight this post!
Unread 17-03-2004, 21:22
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
if you push it in reverse and let go does it keep going in reverse? or go forward?
[EDIT] I also think it is a switch wiring problem [/EDIT]
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
  #18   Spotlight this post!
Unread 17-03-2004, 21:28
the thing is that....the SAME EXACT thing happens when i hooked up a joystick to it...so i doubt its an electrical problem.
*EDIT - using the triggers from a joystick
  #19   Spotlight this post!
Unread 17-03-2004, 21:33
The Lucas's Avatar
Could you post the file then? The algorithms on this thread are good so the problem is somewhere else. I am sure with all the CD programmers someone will find it real quick.
Robot Inspector
  #20   Spotlight this post!
Unread 17-03-2004, 22:16
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Originally Posted by AsimC
hmm this is how i originally did it...but it doesnt work. What happens is when i click the trigger, its constantly going forward even when i let go.
Code:
if (p3_sw_trig==1)
   pwm07=175;
   pwm08=175;
if (p3_sw_top==1)
   pwm07=90;
   pwm08=90;
the reason why your motors keep running is because there is no path in your code where you tell them to be = 127 and stop running
the way your code is written if neither switch is closed then the pwm outputs will still be what they were the last time the loop ran, and the time before that... your code leaves them at 175 or 90.
you could put
pwm07=127;
pwm08=127;
above your if statement - have them = 127 by default, then if either switch is closed they will be something else instead
this is a common mistake
  #21   Spotlight this post!
Unread 17-03-2004, 22:48
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Rookie Year: 1999
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
try this its the code i use to run my claw modified for your application
Code:
pwm07=127;
pwm08=127;
if (p3_sw_top)
{ pwm07 = 90;
   pwm08 = 90; }
else if (p3_sw_trig)
{ pwm07 = 175;
   pwm08 = 175;}
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
  #22   Spotlight this post!
Unread 17-03-2004, 23:00
adventrx327's Avatar
adventrx327 adventrx327 is offline
adventrx327 is on a distinguished road
Send a message via AIM to adventrx327
Here is how i would write it if i were you guys....
if ( 0 != p3_sw_trig)
pwm07 = 175;
pwm08 = 175;
else if (0 != p3_sw_top)
pwm07 = 90;
pwm08 = 90;
else
{ pwm07 = 127;
pwm08 = 127;
When writing my code i didnt do p3_sw_top == 1, my mentor sez its better to do 0 !=, and i have no idea why.
try this, if it works yay! if not sorry i couldnt be of more help
  #23   Spotlight this post!
Unread 17-03-2004, 23:07
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Here is the reason: http://www.chiefdelphi.com/forums/sh...34&postcount=3 However, in the future don't be afraid to ask your mentor to explain things like that you don't understand.
  #24   Spotlight this post!
Unread 17-03-2004, 23:20
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Team Role: Leadership
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Code:
pwm07 = pwm08 = 127 + ((p3_sw_trig - p3_sw_top) * 40);
One line. I found it very useful this year. You can changew the numher at the end (40) to whatever scale you want. trig will make it go forward, top will make it go back, and either both or none will make it just sit there.
-Kesich
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
  #25   Spotlight this post!
Unread 18-03-2004, 00:30
Oh my god!
So concise, so effective, so 1337!
I salute you Anthony, you truly embody the spirit of first.
  #26   Spotlight this post!
Unread 18-03-2004, 07:01
it is concise in C - but unless the CPU has a HW multiplyer then multiplyer that one line of code might compile into something that will take hundreds of machine cycles to execute in assembler
when you only need an '=' getting clever to make your C look concise is usually a big mistake.
  #27   Spotlight this post!
Unread 18-03-2004, 11:00
The Lucas's Avatar
Actually both routines, Anthony Kesich's one-liner and Xufer's selection structure, take exactly 22 bytes of program space, just check the list file (FrcCode.lst) after compiling both. Xufers routine was the most program space efficient of the selection structures I saw because it involved the least branching (i.e. no else to set neutral which only takes 2 bytes). Anthony’s routine could probably be optimized in assembler since only the sign bit and least significant bit of one of the factors is relevant (I don't program in assembler so I am not sure). One-liners are much better for relays because it is simply addition no multiplication.
Processor speed is a different story and depends on the processor architecture.
Robot Inspector
Digital In Question Tom Bottiglieri Control System 5 02-03-2004 17:09
Urgent!! (programming question) anupalsingh Programming 6 25-02-2004 10:53
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
C Programming Question tophq Programming 7 16-02-2004 12:56
Programming question archiver 2001 6 23-06-2002 22:57
