Go to Post So yeah I love the minibot because it was a great vehicle to promote our team, make new friends, and possibly make sure a team makes it past their 1st or 2nd year. - Mr V [more]
Unread 20-02-2002, 15:00
kacz100 kacz100 is offline
Battle Cattle!
#1466 (Webb Robotics)
kacz100 is on a distinguished road
Send a message via AIM to kacz100 Send a message via Yahoo to kacz100
Goal Lifting!?!?!?!
If a team lifts a goal completely off of the ground and your robot is designed to interact with the bottom platform of the goal and now it is above your robt frame does this DQ you or the robot that lifted the goals? Or something along that line
Kacz
Team #40 Alumni 1999 - 2002
Team #885 College Student/Mentor 2003
Team #1466 College Student/Mentor 2004
Unread 20-02-2002, 15:11
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
No Interaction with Underside!
Yes. Any interaction with the underside of the bottom platform of the goal is illegal and you will be DQed for touching it. It is not illlegal to lift the goal up, so long as you do not touch the underside of the bottom platform. If another robot lifts the goal up high enough that your robot can drive under it and your robot touches the underside fo the goal (from my understanding) you would be DQed - because it is completely illegal to have any interaction with the underside of the bottom platform of the goal. Though I would like to see a robot that could lift the entire goal completely off of the ground - especially without touching the underside!!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 20-02-2002, 15:23
kevinw kevinw is offline
kevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to all
Re: No Interaction with Underside!
Please see the following.
http://www.chiefdelphi.com/forums/pi...rrow=4&trows=3
Unread 20-02-2002, 15:40
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
bah. that isn't completely off the ground. although, it is rather impressive. we planned our robot to d osomething like that, but then kinda ran out of additional weight, so redesigned our systems.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 20-02-2002, 15:53
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Look closer and you'll see the full shadows of the goals beneath the casters. It's much more obvious on the right goal than on the left. The outside of the left goal is about 1 inch off the ground and the outside of the right goal is about 3 inches off the ground. The goals are uneven and drooping to the outside a bit because the top link of our arms were not yet adjusted when the picture was taken. The goals lift completely level now that the arm is adjusted.
-Chris
Unread 20-02-2002, 15:58
A picture's worth
Sometimes a picture's worth 1000 words. Sometimes seeing isn't quite believing. Since you guys won't be at the GLR or the WMR, all I can do is invite you to watch us at Nationals.
Unread 20-02-2002, 16:56
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Rookie Year: 1999
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
Quick question with the goals being raised only 3 inches do you think that is safe enough from not being hooked on? What about an opposing robot just smashing into the goal and causing you to drop it. I don't believe lifting a goal is the answer because it causes too much vulnerablily to a robot. If someone knows what I am talking about or disagrees with me please reply
Unread 20-02-2002, 16:58
College? What?
ok, i'll agree that the goal is off the ground, but a few question ,which you might not answer just yet...
1) How long does it take to get the goals in the air?
2) How strong is your arms?
3) What happens if you only have one goal?
if you don't answer them, i understand. but, if you could, at least answer one of them.
AIM --> Woloi
Unread 20-02-2002, 18:24
Dave Hurt Dave Hurt is offline
Mostly Harmless
FRC #6413 (Degrees of Freedom)
Rookie Year: 1999
Dave Hurt is on a distinguished road
I'll save Chris and Kevin the work on this one :-) I havn't seen the robot pass the planning stages myself, but if you check out the link below, it answers all those questions. And you gain a hugh advantage by picking both goals up. Instead of a 130 pounds from the robot interacting with the floor, you have the 130 pound robot and two 180 pound goals. It's like trying to push a VW Bug vs a Semi. The semi has the clear advantage. And if they loose enough weight to put the cvt back on, I can pretty much guarentee no one is going to be pushing them around very easily.
http://www.chiefdelphi.com/forums/sh...&threadid=2619
Unread 20-02-2002, 19:00
What I meant to say...
Kevin,
I saw that picture in the gallery before - that's awesome! Great job, lol! What I meant to say was "I would like to see a robot that can lift the goals completely off the ground, high enough for a robot to go underneath!" Yea...
- Katie
Student - 2001-2004
Mentor - 2006-2009
Unread 21-02-2002, 09:45
Rookie Year: 1997
We'll wait for the competitions to start to reveal more.
Unread 21-02-2002, 13:08
FlyFisher FlyFisher is offline
FlyFisher is an unknown quantity at this point
Not only is lifting two goals a good idea, but if they can be spun around at the same time, that would be awesome!!! Take a look at www.Team60.net
Unread 21-02-2002, 13:36
College? What?
yes, but then you must get two goals, or else your robot will tip over and that's not good.
AIM --> Woloi
Unread 21-02-2002, 15:39
gniticxe's Avatar
gniticxe gniticxe is offline
B.C.O.M. Forever!
AKA: Brian Gattman
FRC #2910 (Jack in the Bot), FRC #0365 (MOE, Alumnus)
Rookie Year: 2000
gniticxe will become famous soon enough
I just posted the reveal for MOE 2002 (who can lift goals) heres a link to the thread:
http://www.chiefdelphi.com/forums/sh...&threadid=2718
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
