Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 19-03-2004, 10:54
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Globe motor - no lubrication in gears!
One of our Globe motors was making a grinding noise after a tough match, so I dismantled it. The 2 sets of planetary gears inside were completely dry - with only dried residue of whatever grease was put in during manufacture.
It runs much smoother and quieter now after I added some lubricant (Honda Moly 60 grease).
To dismantle the gearbox you push the three small roll-pins around the circumference all the way into the gearbox. You can then pull the gearbox off the motor. To reassemble, you push the roll pins back in from the outside.
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
