Go to Post I didn't say it bad English, though. Grammatically, it's perfectly proper. - Greg Ross [more]
Unread 19-03-2004, 22:01
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Why I love engineering.
A valuable engineering lesson learned at the SBPLI Regional Event:
We have a rear climbing piston to help us up the 6" step. Sometimes (always) it gets stuck on the diamond plate and bends as we try to drive forward. This is okay unless we REALLY bend it, because then it doesn't come back out.
The first time we did this, we took the piston off and replaced it with our only spare. If it happened again, we thought, we were done. Then I went to work on the old piston. I was able to get it back out by putting it in a vice and twisting, but it would still jam up if I tried to push it back in. I tried to step on it and bend it back, but this was useless...it is a 1.5" bore piston and is pretty strong. I tried putting it in the vice and pulling as hard as I could, but that didn't work either.
Then I remembered engineering rule number one: if it doesn't work, hit it really hard. I looked at it too see which way it was bending, turned it the opposite way, and slammed it into the ground. Sure enough, it worked perfectly!
Now when we bend them, we swap the bent one out and the good one in and hit the bent one into the ground really hard...the whole process take about 3 minutes and has saved us 5 pistons so far.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 20-03-2004, 00:27
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Why I love engineering.
thats because the noise is leaking out during the match
if you hit it hard enough, you are putting a sufficient amount of noise back in - enough for one match :^)
Mechanical parts run on noise
electrical parts run on smoke
Unread 20-03-2004, 19:13
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
and the rest runs on luck...or lack thereof in our case.
Battlebots I.Q.- A serious threat to FIRST or a half thought up cheep copy? Joe Matt General Forum 75 17-10-2005 20:43
Problems with College Engineering Programs Gabriel Chit-Chat 3 18-04-2004 18:35
Fav. Beatles Song MattK Chit-Chat 17 04-12-2002 17:18
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Engineering vs. Engineering Technology archiver 2000 4 24-06-2002 00:07
