Go to Post At every event I've seen this year, there has been at least one robot that left a part on the field. Even some of the robots have decided they don't want to play and this year and made a break for it in autonomous! :yikes: - ctt956 [more]
Unread 19-03-2004, 22:25
punarhero's Avatar
punarhero punarhero is offline
#0696 (Clark Magnet Robotics)
punarhero is an unknown quantity at this point
Send a message via AIM to punarhero Send a message via Yahoo to punarhero
Advanced Programmer Needed!!!
Hi everyone,
We have a robot project that is due in two weeks. We are using the Innovation First robot controller to output digital outputs to the parallel port of an on-board computer. This is what we need:
We need someone who could write a program for us in windows of our computer to read different pin combinations on the parallel port and have the computer play different audio tracks. If you know someone or you could write the program for us, please contact me ASAP. We could compensate for your time. Please contact me via e-mail or cell phone.
E-mail: punarhero@yahoo.com
Cell: 818 472 3925
Home Phone: 818 550 8297
Thanks a lot
Punar Sikka
Team 696
www.team696.org
Unread 19-03-2004, 22:39
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Advanced Programmer Needed!!!
Yes?
:SMACKED!:
Why parallel? And how are you connecting to the parallel port? the prog port is serial.
MSDN
I ask because the MSCOMM control is really easy to use, but it only does COMM (RS-232).
What IDEs do you have? I've gotten pretty good calling APIs in VB.
[What version of windows are you using?]
Unread 20-03-2004, 23:09
punarhero's Avatar
Well,
There is nothing specific about using parallel. Basically we are going to hard wire digital outputs from our robot controller directly into the parallel, or for that matter serial (if that's easier), port. This way, every time the robot reaches a place where it has to play a new audio track, it will output a unique combination of signals, which we need to be picked up by the serial or parallel port. Is there any way If can contact you, messenger or phone, please let me know since this is a bit urgent.
Thanks a lot
Punar Sikka
Team 696
www.team696.org
Unread 20-03-2004, 23:55
philipprogramer philipprogramer is offline
#0762 (Patriots)
Team Role: Operator
philipprogramer is an unknown quantity at this point
is there any need for the computer to be connected directly to the robot or could you just rewrite a dashboard program for the OI?
Team 762
1st Seed UCF 2003
7th Seed UCF 2004
Quater-finalists (thanks 312 and 59)
GM Industrial Design Judge's Award UCF 2004
ANYTHING is Possible
Unread 21-03-2004, 04:09
punarhero's Avatar
I guess you could just reqrite the dashboard program. I didn't think of that. That would be a lot easier to program than the parallel port. We are using last year's robot controller. Do you have the dashboard program from last year. Also, was it just VB or something else that it was written in. That might be a easy solution.
Punar Sikka
Team 696
www.team696.org
Unread 21-03-2004, 05:57
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
You can write it in anything that you want to, as long as it works with the serial port the same.
Unread 21-03-2004, 10:59
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Actually, the parallel port is a lot easier to program in my opinion. You can just get a free dll that allows access to the port under WinNT/2000/XP (if you use it - Win9x will work with no dll) and read/write to the port with just one command.
Programming the CD Audio in VB is even easier. The multimedia control can do that with almost no code required.
Unread 21-03-2004, 15:29
AKA: Jamie Bliss
And combine that with the dashboard control for vb, and your set!
White Paper Discuss: All I Ever Needed to Know I learned in FIRST poster CD47-Bot Extra Discussion 5 28-03-2005 15:44
Image Needed Tarsen Website Design/Showcase 1 17-10-2003 23:22
The Grand FIRST team.. programmers and others needed randomperson Programming 0 31-05-2003 23:46
problems with our programmer AlphaOmega870 Programming 12 31-01-2003 08:23
Inventor 5.0 help needed Larry Barello Inventor 4 27-01-2002 10:54
