Go to Post The competition is about MUCH more than just the robot. If kids are glued to the robot all of the time, then they miss the rest of it... the other fun stuff, what makes FIRST, FIRST. - Kims Robot [more]
Unread 20-03-2004, 23:06
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
One last question about our code
WE got our code from kevin.org this year. When we run our final copy of the autonomous code the recievers move back and forth on our servos to find the beacons since i do not have the beacons i am not sure if it then switchs back to the navigate part of the program or just stops and says sensor 1 found . The thing that i want to know the most is why doe our sensors move back and forth when we are in normal mode but when we are in autonomous they stop and no other functions seem to happen like our navigate code. Also the default is included in the assembly file but it does not seem to work in our normal mode. Any help will be gladly accepted
"I'm sorry, after all he is just a wookie!"
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Need interupts help, and another question... Kevin Karan Programming 7 22-02-2004 11:20
navigate and default code newbie question alan koch Programming 2 17-02-2004 22:25
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
