Go to Post hmmm... big open space between arena and pits... thousands of poof balls...thousands of high school kids hopped up on sugar and robotics.... sounds a little dangerous. - Courtneyb1023 [more]
Unread 20-02-2002, 21:58
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
Brake design for Chalupas
My advidor was saying today that there is a way of making the chalupa motors brake. I have found no reference to this anywhere. Is this possible and if so how?
Unread 20-02-2002, 22:10
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Team Role: Teacher
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
The brake we were going to use was a electronic one using the force to stop the turn
harder you pull harder it wants to stop.
Unread 20-02-2002, 22:36
RobZeuge RobZeuge is offline
RobZeuge is an unknown quantity at this point
Send a message via AIM to RobZeuge
You can use the speed controller...
You can set the speed controller to brake mode. This will stop the motor from coasting. You should remember that this will disperse alot of energy through the mtor itself in the form of heat, which can cause damage (especially if the motor is on your drivetrain)
Good Luck
Robert Zeuge
Unread 20-02-2002, 22:41
Good Luck
Robert Zeuge
Unread 21-02-2002, 00:10
mnkysp6353's Avatar
ok how do i do this?
Unread 21-02-2002, 07:38
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
Just move the small jumper over on the speed controller. Real quick easy change. I always try our different motors out using both settings, finding out which one I like best. btw, they aren't perfect. The only way to truely prevent backdrive is to use a potentiometer or other sensor and do it in the code.
~Tom Fairchild~
Unread 21-02-2002, 12:16
jonnywalk jonnywalk is offline
jonnywalk is an unknown quantity at this point
Send a message via AIM to jonnywalk
Brake
just a suggestion but I would use a brake other then electronic to hold the bot down so that you don't stall motors and start tripping brakes. I designed a brake for our bot using other forces motors( not electronic motors) it works VERY well and I challenge anyone to move our robot when I stop it. Just a suggestion but a hint is you have the cyliners and air compressor that draws minimal amps and dosen't stall!!!!!!!!!!!!!! The brake took the last 7 hours of Monday night to design and build into the bot but if you plan ahead you should be able to add one at regionals before you compete with little trouble.
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
what kind of design are people going for? mrobrien Rules/Strategy 47 02-04-2003 12:23
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
Team 401's design jonnywalk Technical Discussion 2 30-01-2002 23:02
