Go to Post Rules arent built around robots. Robots are built around the rules. - dodar [more]
Unread 22-03-2004, 10:02
omega's Avatar
omega omega is offline
omega is an unknown quantity at this point
how are we going to do this
This is what we have for our automous code but we want to go from the Navigate(); to what is beneath it when both of the sensors see nothing becuase we don't want to risk loseing all of that time.
void User_Autonomous_Code(void)
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
Navigate();
if(rc_dig_in01 ==1 )
pwm13 = 137;
pwm14=100;
else
pwm13 = pwm14 = 140;
if(rc_dig_in02 == 1)
pwm13 = 100;
pwm14 = 137;
else
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
Unread 22-03-2004, 10:44
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: how are we going to do this
I think you said it yourself, just say it in C:
Code:
   Navigate();
  if ( NEITHER_SENSOR_SEES )
    pwm13 = 137;
    pwm14=100;
     else
    pwm13 = 100;
    pwm14 = 137;
   else
However, it may be more appropriate to change Navigate() to keep going when blind. Are you using IR trackers?
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 22-03-2004, 11:32
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
You should move navigate() to before the spidata thing if you are using the old navigate routine
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
