Go to Post Welcome to The 2018 FIRST Robotics Competition: Bureaucracy Bash! - Andrew Schreiber [more]
Unread 23-03-2004, 23:14
tophq's Avatar
tophq tophq is offline
mastr of autodsk (or not)
AKA: Chris Payk
#0703 (Inferno)
tophq is an unknown quantity at this point
not quite sure...speed controller...spike.
ok, we just got back a couple days ago from Detroit Regional and now I have couple questions.
1. is it necassary to use a speed controller on ALL motors, or can i (legally) use a spike for the window motor?
2. if i have to use a speed controller, then what (for example) would i do to make a motor used to power a wench as far as coding goes? (ie, if i wanted to use the p2_sw_aux1 to retract the wench, would i say:
Code:
if(p2_sw_aux1 == 1)
     pwm05 = 255
else
     pwm05 = 127
when we used a speed controller, for some odd reason, the motor would activate and start retracting the wench. when we swapped it out for a spike (and changed the code accordingly), it worked out beautifully.
3. can anyone help out.
sorry if this post sounds jumbled, im kind of in a hurry. any help would be thanked greatly.
Unread 23-03-2004, 23:18
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: not quite sure...speed controller...spike.
This may or may not be related, but i have found that lots of joystick buttons seem to flicker IE not giving a constant stream of 1's when they are being pressed. Our code now checks the button over the period of 3 or 4 frames to make sure its really pressed. This is probably a good idea for a winch button anyway, you wouldnt want it accidentally pressed.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 23-03-2004, 23:23
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
255 is not a valid output for pwms (victors) - it can make the communcation between your code and the layer above it lose synch
254 is the max you should ever output
that might be why your victor wacked out
or it could be it wasnt calibrated correctly - if you are certain you are sending it 127 and the motor is still trying to move, then it either needs to be recalibrated, or its not working correctly.
to answer your original question, it says in the robot section of the manual which motors you can use with spikes - Im almost certain a window motor would be ok.
Unread 23-03-2004, 23:52
wow! im impressed that you discovered that by yourself!
Its called 'switch bounce' - when you close a switch or pushbutton it takes about a 1/10th of a second for it to make solid contact - the surfaces actually do bounce a tiny bit - so if a fast microprocessor is polling the switch it will see it go 00001101010011110111111011111111111
and your timing is right - 3 frames is about a 100 mS
nice catch!
Unread 24-03-2004, 05:37
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
I will add that, in our code we had values of 255 being output and weird things were happening. I chnaged it after I saw something on here and the problem went away. At the same time I also changed something else, so it may be a coincidence though.
Unread 23-03-2004, 23:20
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
KevinB will become famous soon enoughKevinB will become famous soon enough
Send a message via ICQ to KevinB
You may use a Spike for the window motor.
Code:
if(p2_sw_aux1 == 1)
     pwm05 = 255
else
     pwm05 = 127
This code looks valid, except you are missing semicolons at the end of the "pwm05 = XXX" statements. Also, I'm not sure if this applies to the new controller, but the old controller didn't like PWMs being set to 255 -- we were told to use 254 instead.
when we used a speed controller, for some odd reason, the motor would activate and start retracting the wench. when we swapped it out for a spike (and changed the code accordingly), it worked out beautifully..
I'd be willing to bet this was probably caused by some code error that you accidentally remedied when you changed to the Spike. If you posted the exact old and new code, we might be able to better help you.
Unread 24-03-2004, 06:28
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
Team Role: Teacher
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
We had our winch motor controled by a spike. At the AZ regional inspection they told us all moters MUST be controlled by a controler, not a spike. We swapped them out and we use code like yours, except our max was 254.
Unread 24-03-2004, 06:56
Programming User
The seat motor and the window motor can be powered by a spike. (See http://www2.usfirst.org/2004comp/5-T...corporated.pdf, <R35>)
--EDIT--
Maybe they mean't all the motors on you robot.
Unread 26-03-2004, 13:43
tophq's Avatar
AKA: Chris Payk
#0703 (Inferno)
ok, i guess then we'll stick with a controller. sorry about the code i posted above. i ALWAYS forget to place those semi-colons there, then when i try to build the code, it fails and i instantaniously know what happened. i should really get some help for that problem (anyone want to start a support group...lol). ok, i'll try to make those changes when we get to canada. man i wish i was a real programmer...lol. thanks people!
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
