Go to Post We were also at 9,999 [characters] for Chairmans...Mom always said I was an under-achiever. - Chris Fultz [more]
Unread 24-03-2004, 09:37
CrashZero's Avatar
CrashZero CrashZero is offline
Computer Nerd
#1352 (Huskie Robotics)
CrashZero will become famous soon enoughCrashZero will become famous soon enough
Exclamation What is wrong with this code???? It won't Compile and I don't know why? Please Help
* TITLE: navigate.c
* VERSION: 1.0
* DATE: 08-Jan-2004
* AUTHOR: Richard D. Petras
* COMMENTS:
* CHANGE LOG:
* DATE REV DESCRIPTION
* 04-Dec-2003 0.2 RDP Added Tracker to drive robot to goal
* 06-Dec-2003 0.3 RDP First implementation of drive algorithm
* 07-Dec-2003 0.4 RDP Got rid of servo glich by NOT disabling interrupts in
* Timer 1 handler
* 08-Jan-2004 1.0 RDP The version used at the 2004 kickoff
#include "ifi_picdefs.h"
#include "ifi_default.h"
#include "ifi_aliases.h"
#include "ifi_utilities.h"
#include "printf_lib.h"
#include "user_routines.h"
#include "navigate.h"
// Global Variables
int Navigator_State = WAIT_TO_DRIVE;
* FUNCTION: Navigate()
* PURPOSE: Controls the left and right drive motors in order to
* drive to an infrared beacon. This routine depends on two
* beacon trackers to point the the IR beacon. It then uses
* the current servo angles to determine when to turn
* the robot to get to the goal. When the angles are
* sufficiently small, we are at the target and stop.
* The vehicle starts out stopped (WAIT_TO_DRIVE)
* You might want to skip this state in autonomous mode :-)
* When a button is pressed it starts to drive (DRIVE_TO_CENTER).
* This drive is very short(just enough to move away from the
* wall. Next we search until one of the trackers sees the
* beacon (TURN_TO_TARGET). Then we drive toward the target
* (DRIVE_TO_TARGET) until we pass it (PASSED_TARGET). Then
* drive until the trackers are both beyond the goal point
* (AT_TARGET). During all of this we are watching the current
* to see if it exceeds the expected maximum value(OVER_CURRENT).
* PARAMETERS: none
* RETURNS: nothing
* COMMENTS: The values set in navigate.h are very dependent on the
* particular robot configuration and will require some tuning
* for your robot.
void Navigate()
// Note: Statics are used to retain the variable values across
// calls. Otherwise, the values stored inside a function are not
// guarenteed to remain the same.
static unsigned int Old_Clock = 0; // A place to store the last clock value
static unsigned char drive_timer = 0; // Timer for driving forward in 26 msec steps
static unsigned char left_drive_set = LSTOP; // Start out stopped
static unsigned char right_drive_set = RSTOP;
static unsigned char left_servo_set = 127; // Trackers pointed straight ahead
static unsigned char right_servo_set = 127;
int left_error, right_error; // Errors from the tracker goal
int left_state, right_state; // Left and right tracker state
static unsigned int left_current[10] = {0}; // This is a circular buffer for
static unsigned int right_current[10] = {0}; // storing current values. We
// need this because the sensors
// are noisy. We'll take an avg
// of the last ten values.
static int i = 0; // Current buffer counter
unsigned int left_current_avg, right_current_avg;
int n; // Counter
int drive_state = DR_UNDEFINED;
if (Clock > Old_Clock) // stay synchronized to beacon data updates (this is important)
left_current[i] = Get_Analog_Value( rc_ana_in01 ); // Get the currents for
right_current[i] = Get_Analog_Value( rc_ana_in02 ); // each wheel. Just comment
// out all the current code
// if not using current sensors
// If we get a high current value, check the last ten to be sure its not just a glitch
if (((left_current[i] > MAX_CURRENT) || (right_current[i] > MAX_CURRENT)) &&
(Navigator_State != WAIT_TO_DRIVE) && (Navigator_State != AT_TARGET))
// Maybe this is real, but current sensors can be noisy
// Check the last ten values to see if they agree
left_current_avg = 0;
right_current_avg = 0;
for (n = 0; n < 10; n++)
left_current_avg += left_current[n];
right_current_avg += right_current[n];
left_current_avg /= 10;
right_current_avg /= 10;
if ((left_current_avg > MAX_CURRENT) || (right_current_avg > MAX_CURRENT))
Navigator_State = OVER_CURRENT;
printf("Left_current = %d Right_current = %d\n", left_current_avg, right_current_avg);
printf("OVER_CURRENT\n"); // Over current
drive_timer = 0;
if (i++ >= 10) i=0; // Reset our circular buffer counter if needed
// This is the main Navigator state machine implemented as a switch statement
switch (Navigator_State)
// Just wait until a button is pressed before we start (skip for autonomous mode)
// case WAIT_TO_DRIVE:
// Don't go anywhere
// Eyes forward
if (p1_sw_trig)
Navigator_State = DRIVE_TO_CENTER;
printf("DRIVE_TO_CENTER\n"); // Driving to center
break;
case DRIVE_TO_CENTER:
// Drive away from the wall.
left_drive_set = FFWD;
right_drive_set = FFWD;
if (drive_timer++ > DRIVE_TO_CENTER_TIME)
Navigator_State = TURN_TO_TARGET;
printf("TURN_TO_TARGET\n"); // Done driving to center
break;
case OVER_CURRENT:
// If we get here let's back off a little and start over
// Note: we could do better here if we remembered that we
// passed the target. (Exercise left to the student :-))
break;
case TURN_TO_TARGET:
// Point trackers straight ahead, then turn
// until at least one tracker sees the beacon
left_drive_set = SBWD;
right_drive_set = SFWD;
if (((LL) && (LR)) || ((RL) && (RR)))
Navigator_State = DRIVE_TO_TARGET; // At least one sensor sees the target
printf("DRIVE_TO_TARGET\n");
break;
case DRIVE_TO_TARGET:
case PASSED_TARGET:
// As long as we are locked on to the beacons with both targets
// drive toward them
Track_Beacon(LEFT); // allow the left beacon tracker state machine to run
Track_Beacon(RIGHT); // allow the right beacon tracker state machine to run
// update the servo PWM values with the values calculated by Track_Beacon() above
left_servo_set = Tracker_Data[left].Position;
right_servo_set = Tracker_Data[right].Position;
if ((Tracker_Data[left].Status == BOTH_IN_VIEW) &&
(Tracker_Data[right].Status == BOTH_IN_VIEW))
// We are locked on with both targets, so drive!
// Find out which way the servoes are pointed
if (left_servo_set < 127) // Left servo pointed left
left_state = DR_LEFT;
else if (left_servo_set > LEFT_GOAL) // Left servo pointed right
left_state = DR_RIGHT;
else
left_state = DR_CENTER;
if (right_servo_set > 127) // Right servo pointed right
right_state = DR_RIGHT;
else if (right_servo_set < RIGHT_GOAL) // Right servo pointed left
right_state = DR_LEFT;
else
right_state = DR_CENTER;
// Now find out the drive state
if (left_state == DR_LEFT && right_state == DR_LEFT)
drive_state = DR_BOTH_LEFT;
else if (left_state == DR_RIGHT && right_state == DR_RIGHT)
drive_state = DR_BOTH_RIGHT;
else if (left_state == DR_RIGHT && right_state == DR_LEFT)
drive_state = DR_BOTH_CENTER; // At goal
else if (left_state == DR_CENTER && right_state == DR_CENTER)
drive_state = DR_BOTH_STRAIGHT;
else if (left_state == DR_CENTER)
drive_state = DR_LEFT_STRAIGHT;
else if (right_state == DR_CENTER)
drive_state = DR_RIGHT_STRAIGHT;
else
drive_state = DR_REFLECTION; // Impossible angle, but could happen
drive_timer = 0; // As long as we see the target keep driving
// Drive logic starts here
switch (drive_state)
case DR_UNDEFINED:
// We should not be able to get here
printf("DR_UNDEFINED\n");
break;
case DR_BOTH_LEFT:
// Go straight until we pass the target
if (Navigator_State == DRIVE_TO_TARGET)
// Don't turn left
left_drive_set = SFWD;
else
// We are in PASSED_TARGET state
// Turn left
if (left_servo_set < LEFT_PASS)
Navigator_State = PASSED_TARGET;
printf("PASSED_TARGET\n");
break;
case DR_BOTH_RIGHT:
// Don't turn right
else
// Turn right
right_drive_set = SBWD;
if (right_servo_set > RIGHT_PASS)
break;
// The beacon is ahead in all these cases so just drive
case DR_BOTH_STRAIGHT:
case DR_LEFT_STRAIGHT:
case DR_RIGHT_STRAIGHT:
// Note: we don't know what to do here but we might as well keep
// going.
case DR_REFLECTION:
// Find the error from ideal on each side
left_error = (int)LEFT_GOAL - (int)Tracker_Data[left].Position;
right_error = (int)Tracker_Data[right].Position - (int)RIGHT_GOAL;
// Scale the error
left_error *= DRIVE_GAIN;
right_error *= DRIVE_GAIN;
// Use these if you want fractional gain values
// Be sure to comment out the above gain lines
// left_error /= DRIVE_GAIN;
// right_error /= DRIVE_GAIN;
// Make sure the errors are in range
if (left_error > (255 - SFWD)) left_error = 255 - SFWD;
if (right_error > (255 - SFWD)) right_error = 255 - SFWD;
if (left_error < -SFWD) left_error = -SFWD;
if (right_error < -SFWD) right_error = -SFWD;
// If we are pointed left, drive the right drive faster and vice versa
// Use the next two lines to turn toward the goal
// left_drive_set = SFWD + right_error;
// right_drive_set = SFWD + left_error;
// These two lines keep driving straight
// printf("Lerr = %d Rerr = %d\n",left_error,right_error);
// End of drive logic
break;
case DR_BOTH_CENTER:
Navigator_State = AT_TARGET; // Both servos are within the target threshold
printf("AT_TARGET\n");
break;
else
// We are not locked on - Stop
// give the trackers a chance to catch up
drive_timer++ ;
if (drive_timer > LOST_TARGET_TIMEOUT)
break;
case AT_TARGET:
// We are at the goal - Stop driving
break;
default:
printf("Not a valid state\n");
break;
// Send all the control values to the pwm controller
//printf("Left = %d Right = %d\n", (int)left_drive_set, (int)right_drive_set);
left_servo = left_servo_set;
right_servo = right_servo_set;
left_drive = left_drive_set;
right_drive = right_drive_set;
// left_drive = 255 - left_drive_set; // This drive is reversed
// right_drive = 255 - right_drive_set; // This drive is reversed
Old_Clock = Clock; // take a snapshot of the clock
//PLEASE HELP ME IF YOU CAN!!!!!!
This is our world now... the world of the electron and the switch, the beauty of the baud. We make use of a service already existing without paying for what could be dirt-cheap if it wasn't run by profiteering gluttons, and you call us criminals. We explore... and you call us criminals. We seek after knowledge... and you call us criminals. We exist without skin color, without nationality, without religious bias... and you call us criminals. You build atomic bombs, you wage wars, you murder, cheat, and lie to us and try to make us believe it's for our own good, yet we're the criminals. Yes, I am a criminal. My crime is that of curiosity. My crime is that of judging people by what they say and think, not what they look like. My crime is that of outsmarting you, something that you will never forgive me for. I am a hacker, and this is my manifesto. You may stop me, but you can't stop us all...
quote from:
+++ The Mentor +++
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
How to measure execution time? And code size? gnormhurst Programming 17 17-02-2004 08:06
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
