Go to Post Nothing motivates people to join like the promise of a trip to far-away lands of regional/championship competition during school days :) - Joe G. [more]
Unread 24-03-2004, 22:03
Pattyta Pattyta is offline
Pattyta is on a distinguished road
Number of sensors in the IR
Hello,
Our team is working on the IR but only with two sensors.
The kevin.org code works with 4 and i dont know how to change it to two???
or is there a better way
Rokie team needs help plz
Unread 25-03-2004, 09:07
CrashZero's Avatar
CrashZero CrashZero is offline
Computer Nerd
#1352 (Huskie Robotics)
CrashZero will become famous soon enoughCrashZero will become famous soon enough
Question Re: Number of sensors in the IR
Can you post some of the code that you want to change? Then I might be able to help you.
This is our world now... the world of the electron and the switch, the beauty of the baud. We make use of a service already existing without paying for what could be dirt-cheap if it wasn't run by profiteering gluttons, and you call us criminals. We explore... and you call us criminals. We seek after knowledge... and you call us criminals. We exist without skin color, without nationality, without religious bias... and you call us criminals. You build atomic bombs, you wage wars, you murder, cheat, and lie to us and try to make us believe it's for our own good, yet we're the criminals. Yes, I am a criminal. My crime is that of curiosity. My crime is that of judging people by what they say and think, not what they look like. My crime is that of outsmarting you, something that you will never forgive me for. I am a hacker, and this is my manifesto. You may stop me, but you can't stop us all...
quote from:
+++ The Mentor +++
Unread 25-03-2004, 17:22
#define LEFT_TRACKER_LEFT_SENSOR 0 // entry 0 of Sensor_Stats[] will provide this beacon data
#define LEFT_TRACKER_RIGHT_SENSOR 1 // entry 1 of Sensor_Stats[] will provide this beacon data
#define RIGHT_TRACKER_LEFT_SENSOR 2 // entry 2 of Sensor_Stats[] will provide this beacon data
#define RIGHT_TRACKER_RIGHT_SENSOR 3
all the kevin code is based on the left and right sensors of the tracker, but we only have one sensors per tracker ??
i dont know where should i earase and where not??
Rockie team
Unread 25-03-2004, 18:00
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
The reason for the two sensors per tracker is so that one sensor can see to the left and one to the right, so you always know which way to move the tracker. You could change the design to one sensor per tracker, so long as you restrict it's "sight" to a few degrees ... though the code will not work as well, and you'll have to change some logic. Or you could just put the sensors stationary and use an alternative method.
Judging by
I assume you're not an expert C programmer, well-versed in the code at kevin.org. So editing it a great deal might not be a good idea. In that case, you might want to stick with the setup he has. I don't really understand why you only have one sensor per tracker; is it that you only have two sensors, or that you only use two sensors (you should have received more in the kit and can purchase others if need be).
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
