Re: pic: YMTC: Is 41 hanging?
In the picture, the belt is still on the robot and touching the platform, so they don't count. "Don't be a lawyer", or something like that. |
Something very similar happened in one of our matches actually, except it was with a chain and the refs called it a no hang. But it was a good call because if I remember correctly the rules state that if any part of your robot is touching.
I say no hang. They are touching. How would you feel if you were the other alliance and they counted. I don't think they deserved it because every other team had to build their robot to withstand hits and things breaking so that they would not be touching the platform.
Atleast all of the refs' decisions are uniform. Every example that has so far been given of similar incidents they were ruled as a no hang as well this one for 41. If half of those were counted and the other half were not then I would be cocerned, however, with all of the judges seeming to agree that it is a no hang, then that must be the rule and not up to interpretation.
Last edited by MisterX : 27-03-2004 at 16:48. Reason: too many grammars for my liking |
Yea, that match really did suck. We sheared our left drive pully and we managed to get up and hang with only our right side operational. Cruel twist of fate. Luckily we got someone to the machine shop to make another timing pulley from some Al bar stock. In the meantime, we used the dremel to make new notches!
Thanks to whomever took that pic! |
I say give them the hang because is that tread really supporting any weight. If they believed that it was then they should have taken the tread away and seen if the robot would have fallen. Its like sayin OMG there a little piece of string that is touching the platform and its supporting weight
. They seriously should have been given the hang. |
No, hang, as the rules state no part of the robot may be touching the ground. Though, if I was on 47 I probably would be feeling very different. Though the rules state it. I'm a little surprised at the ruling. The refs at the midwest regional seemed to be extremely leniant about hanging. I saw a couple of robots hanging on the very inner part of the connecction between the vertical and horizontal bar, which was ruled illegal in other regionals.
What if the belt was no longer attached to the robot in any way, but just lying on the platform. Then would you count them as hanging?
Last edited by Joe Ross : 29-03-2004 at 23:41. Reason: oops, its timing belt, thanks Bill |
| YMTC: Bluabot and Redabot hanging? | Natchez | You Make The Call | 15 | 23-03-2004 01:42 |
| pic: Four Hanging | CD47-Bot | Extra Discussion | 6 | 14-03-2004 15:52 |
| pic: Team 48 Robot Hanging | CD47-Bot | Robot Showcase | 1 | 01-03-2004 20:22 |
| pic: rotory walker robot hanging | CD47-Bot | Robot Showcase | 1 | 24-02-2004 08:06 |
| pic: rotary walker side hanging | CD47-Bot | Robot Showcase | 2 | 23-02-2004 12:29 |
