Go to Post I cannot inspire greatness with mediocrity! - Jim Zondag [more]
Unread 31-03-2004, 22:23
roberthan roberthan is offline
None #0702 (Bagel Bytes)
roberthan is an unknown quantity at this point
Send a message via AIM to roberthan
Question Help Motor Help
I'm trying to design a protype crab drive for next year. I am wondering which motors is most fit for the wheels and can you get 4 of them on your robot? Or how do you gear a crab drive with only 1 or 2 drive motors?
Please Help
Unread 31-03-2004, 22:59
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Re: Help Motor Help
Most of the crab drives I have seen used the CIM motors on 2 wheels and the Drill motors on the other 2 wheels- although you would have to gear the motors up or down to a equal ratio. I'd reccomend you check out a robot with crab drive, email a team that has built one, and check out the whitepapers on gearing, etc- [Edit- You can only use the motors that are provided in that year's kit. If FIRST put 4 drill motors in next year's kit (highly unlikely) then you could use a 4 drill motor crab drive. Most likely, you'll have to figure out gear ratios and mess with the CIM and drill)
a crab drive is no simple mechanism, my team (5 years experience) has never built one... last year we witnessed a totally awesome, experienced team struggle through 3 competitions with no functional drive because they mistakenly made their crab drive external- so make SURE your drive is internal (i.e. wildstang, etc) so the crab modules are protected from impact. One hit, and you're dead- good luck with this undertaking, there's nothing better than the feeling when you finish
[edit] check out this whitepaper, ironically 226 used the bosch and FP http://www.chiefdelphi.com/forums/pa...gle&paperid=73 [/edit]
Unread 31-03-2004, 23:56
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Question Re: Help Motor Help
I've been looking at some crab drives lately, so this was a great post to run across. My problem is that I can't open the white page.....is there something I have to load to open it or what. Help would be greatly appreciated.
I get a File Conversion box in MS Works that asks to select the encoding that makes the document readable.....probably my problem.....do I have to download a certain encoding?
Unread 01-04-2004, 01:29
Christian D's Avatar
Christian D Christian D is offline
Son of Captain Nemo
AKA: Christo
#0980 (ThunderBots)
Team Role: Human Player
Christian D is an unknown quantity at this point
Send a message via AIM to Christian D Send a message via MSN to Christian D
Re: Help Motor Help
Please Help
Ask WildStang, they had an awesome robot last year with the crab drive train,
-C
2005 1st Seed Arizona Regional
2005 Semi-Finalist Arizona Regional
2005 Xerox Creativity Award Arizona Regional
2005 Silicon Valley Champions (thanx 254 and 22)
Unread 01-04-2004, 07:44
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Help Motor Help
-C
Thank You!
We use modifications of crab drive from year to year as appropriate. In the past (2003) two wheels had drills and two had FPs. The gearing ws different to provide similar wheel RPM and about 8 Ft/Sec speeds. Come look at our robot in the pits at nationals and bring a camera. Anyone there will be able to give an explanation and let you hold one of the spares for investigation. The module bolts on to the robot base and is removable as a single piece. It contains the motor, wheel, all gearing and at least one will have rotation sensors built on. The unit fits into a virtual cylinder 6" diameter and about 12" high and is driven from above by a Globe and chain. The module is indepenent of the steering so it can be changed out in less than a minute.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-04-2004, 21:07
Ryan F.'s Avatar
Re: Help Motor Help
I got the crab drive inspiration from seeing video of Wildstangs robot from last year. It great watching it slide all over the field.
Would someone Please tell me how I can open up the Whitpaper!!!!
Unread 02-04-2004, 07:18
Unsung FIRST Hero
Rookie Year: 1996
Re: Help Motor Help
The file is zipped so you need an unzip utility. I like WINZIP which you can get freeware from a number of sites. Try this site, it has some great software for free or next to... http://cws.internet.com/16menu.html
Al
WB9UVJ
www.wildstang.org
Unread 02-04-2004, 20:55
Ryan F.'s Avatar
Re: Help Motor Help
Thanks for the help.....but I'm still having problems. I can unzip the file, and get the DWG file, but when I open it up in MS Word, I get a box asking me for an encoding that will make my document readable. If I open it with any other encoding I get something like.
AC1015 sJ V L L W, jx 5 :y a { z0 N( ^A_:M w 6k% )5 k% A %m6((W?D +sI P S I ( b D 3 f 3 33 f3 3 3 3 f 3f ff f f f 3 f ̙ 3 f 3 f 3 3 3 f 3 3 3 3 33 333 f33 33 33 33 f3 3f3 ff3 f3 f3 f3 3 33 f3 3 ̙3 3 3 33 f3 3 3 3 3 33 f3 3 3 3 f 3 f f f f f f 3f 33f f3f 3f 3f 3f ff 3ff fff ff ff ff
--which isn't too usefull
Unread 02-04-2004, 21:57
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
Re: Help Motor Help
If I'm not badly mistaken, .DWG is AutoCAD format, which Word would not be able to view, you would need AutoCAD to check it out.
Unread 02-04-2004, 22:34
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: Help Motor Help
thats correct.......auto cad or any mainstream cad software should be able to interpet the file
Unread 03-04-2004, 00:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Help Motor Help
You can also get free cad file viewer plugins for IE.
Unread 03-04-2004, 00:35
Ryan F.'s Avatar
Re: Help Motor Help
That might be my problem....thanks a lot..I'll have to wait until school to look at it now...darn.
