Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
View Poll Results: Do you use Ternary Operators in your code?
Yes 17 60.71%
No 11 39.29%
Voters: 28. You may not vote on this poll
Unread 02-04-2004, 22:48
NotQuiteFree's Avatar
NotQuiteFree NotQuiteFree is offline
Do the WAAAAVE!!
#0957 (Watson)
NotQuiteFree will become famous soon enough
Send a message via MSN to NotQuiteFree
Do you use ternary operators in your code?
Did anyone use Ternary operators in their code this year? Personally, I find them a little bit...odd. I figure using an if-then statement that says:
if(y > 5)
x = 1;
is easier to read and understand, than:
x = ((y > 5) ? 1 : 0);
But, that is just one man's opinion. What do you all think?
For some more info on Ternary Operators, Binary Operators, and Unary Operators, see
http://cplus.about.com/library/gloss...ryoperator.htm
(This is where I got the example)
Yo.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
