Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Unread 03-04-2004, 13:28
kid robusto kid robusto is offline
AKA: Roger aka:"Jesus" Hubeny
#0195 (cyberknights)
kid robusto is on a distinguished road
Send a message via AIM to kid robusto
Gentoo
HEy, i want to set up a Gentoo box, but i have no idea where to start. i have been to the Gentoo site, and read a lot of stuff there, but i am still confusied.
i have a little bit of tim on mandrake 8.2, but thats abotu it. what stage install should i do?, any other tips anyone may have??
Unread 03-04-2004, 13:50
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Gentoo
If you're new, I would do a stage 3. I personally don't use gentoo, but a few of my friends do. A better place to post a question regarding linux would be www.justlinux.com
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 03-04-2004, 14:03
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Gentoo
Yes, defininetly start with stage three. I'm not that bad a in a Linux environment, and I found the install from stage one to be difficult. Also, after the install, there were many errors every time I booted up. And finally, installing from stage one takes hours, even on a brand-new top of the line machine. (Trust me, it was a long wait for my computer... )
But, there is a newer version out, so maybe things will go better for you.
Unread 03-04-2004, 15:07
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
Re: Gentoo
I use gentoo on the desktop and on the server. It's application management system is just awesome.
As long as you can follow directions, and don't need your computer for 2 days, you can do a stage 1. I would recomend either a Stage 1 or Stage 3, Stage 2 really doesn't do much for performance.
I'd recomend you either print out or have a seperate computer avaliable to view the instructions. It's imperative that you have the instructions while doing the install.
FYI: I did a Stage 1 install on a dual Athlon MP 1600, it took over a day to compile everything.
EDIT: If you do do a stage 1 install, don't get too agressive with the compiler flags. Or you will experience odd errors, or it just plain won't work.
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 03-04-2004, 16:00
Re: Gentoo
Ok the machine i want to put it on is a P1 @200/233 with 192 meg of ram, 2ish gig HDD, and soem other crap. my next queston is i saw read about universal Live Cd, but i cant seem to find it on any FTPs, and i see the stage ones for the i686 and the x86's are only like 15 or 20 megish, is that right for size?
Unread 03-04-2004, 16:03
Team Role: Teacher
Rookie Year: 1999
Re: Gentoo
Stage 1 downloads the source and complies it all. You have to have a working eth0 connection to do a stage 1.
155, teacher: 2011-
Unread 03-04-2004, 16:07
Re: Gentoo
so all i have to do is download the stage 1, and burn it to a cd, and it ~should ~ boot. i see that almost all the files at like tar.bz2 is this a normal format for can be burn like a reg .iso or do i need some special software?
Unread 03-04-2004, 16:20
Team Role: Teacher
Rookie Year: 1999
Re: Gentoo
It will boot to a prompt and you have to give it install commands and everything (I think). You won't be able to do anything other than install.
But don't take my word for it.
As for burning, I have no idea.
155, teacher: 2011-
Unread 03-04-2004, 16:21
Carpe diem
Rookie Year: 1999
Re: Gentoo
1. You need an install CD, also called the live CD (.iso)
2. A data CD with a stage (.tar.bz2) on it
In Gentoo- a stage is a collection of programs that have been pre-compiled. The higher the stage, the more pre-compiled programs you get. The larger the file size of the stage tar ball.
A .tar.bz2 file is usually a group of files that have been archived using the tar utlily. Then, it is run through the bz2 compression algorithm.
Unread 04-04-2004, 12:15
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Rookie Year: 1999
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Gentoo
I'd definitely go with a stage 3 on a pentium I. Starting from stage 1 would probably take up to a week to bootstrap on a machine that slow, with not much of a performance gain compiling. I'd also recommend against a heavy window manager, if you intend to install X. Modern versions of KDE and Gnome would probably border unusable in terms of performance on that sort of machine.
I run gentoo on my laptop and one of my desktops. It's a great distribution, the application management is great (I'd argue easier than RPMs in many cases), the performance is great, and the documentation is wonderful. The best place to start is the Gentoo x86 Installation Handbook, and the stages are avaliable on any of the mirrors, but here's a quick link.
Good luck and happy Gentoo-ing!
Unread 04-04-2004, 13:11
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
Re: Gentoo
You may need a bigger harddrive as well. Since Gentoo compiles everything from scratch, you need a pretty decent sized harddrive to hold temporary compilation files. For instance, OpenOffice.org (which will take a year to compile on that machine) will use over 2 or 3 GB alone during compilation (from my own experience).
Another few things you might want to look into on a computer that slow are DistCC and CCache. DistCC is a Distributed Computing Client, it basically takes other Linux (or Windows running various Linux emulators) machines and uses them to help compile faster. It's not too hard to setup, I believe there's a good document on Gentoo's site, if not just check their forums out, they're one of the best Linux forums I've seen (http://forums.gentoo.org). Look around for Lisa there, she's the developer incharge of DistCC.
As for CCache, it'll take compiles and save them, so if you're compiling the same program over again, it'll go faster. It won't work well with that small of a harddrive, but if you can find a bigger harddrive it can't necessarily hurt to have.
All in all, Gentoo is a very good disto, it's taught me almost all that I know about Linux. If you can, definitely run a Stage 1 installation, because it'll help you to make some connections about how everything works, if you don't already know.
I must say, it's kind of interesting to see how many people use Linux, even more specifically Gentoo, in FIRST. I guess we might be changing the world in more than one way?
AIM --> Woloi
Email --> ian@woloschin.com
Unread 04-04-2004, 18:59
Re: Gentoo
letting the P1 box sit there for a week or two isnt a problem, becasue this box has been sitting uner my stairs for a few weeks,and has no other use.
i D/led the Univerisal live CD for x86, and now im going to get the stage 1 file, should i burn it as a .tar.bz2 or do i need to do somethign special to it first?
Unread 04-04-2004, 19:08
Carpe diem
Rookie Year: 1999
Re: Gentoo
Burn it to a data CD, as a .tar.bz2
Unread 04-04-2004, 19:12
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Gentoo
I tried gentoo a few times, and I have to say that it has the dishonor of being the only linux distribution that I tried where something "broke" without me doing anything.
I set up gentoo from stage 2 on my laptop, and got everything working as I wanted. I used it a few times with no problems (it was installed along side my normal distribution, debian). Then, I didn't touch it for a few months. Then, when I booted into gentoo again, my wireless didn't work. The module no longer wanted to load into the kernel and I had to recompile it.
I'm sure Gentoo is good for a lot of people, just not for me.
  #15   Spotlight this post!
Unread 04-04-2004, 19:13
Programming User
Re: Gentoo
Just to add to that, the point of having fewer pre-compiled files is the size, but more importantly, you get to compile them optimized specifically for your machine.
Yeah, and be careful with the flags. The install I did used as many optimizations as I could figure out, but I ended up with errors.
Choosing a Linux distribution Robby Chit-Chat 8 03-01-2004 23:02
