Go to Post And the rest of the team helped them, encouraged them, and made a big deal about how awesome it was that we were competing for the Chairman's Award. - Carolyn_Grace [more]
Unread 04-04-2004, 00:41
LGuY LGuY is offline
LGuY is an unknown quantity at this point
2003 robot controller & interface
Hiya guys, new here!
I was wondering if anyone can point me in the right direction as to how i can set up the robot controller and operator interface from 2003 (on loan), i tried to just connect everything, following the power distribution guide, and i connected the interface and controller via tether, and the "Valid Rx" light was blinking green on both parts (if im not mistaken its supposed to be a solid green when there is a connection?) and the "no data radio was red (of course, it was on tether).
When i tried to use the radios (yes i connected them to their respective controllers) one was set to receive (the one attached to the robot controller with the rubber antennae), and the one with the metal antennae (operator interface) one's all the lights were on and green (meaning trasmit/power and receive all at once), oh and even with the radios attached it still gave a "no data radio" as blinking red on both controllers.
Further more, i tried to test if it would work with a controll, so i hooked up a victor (following power distribution) and attached the 3 pin cable to one pwm output at a time moving a joystick around to see if the motor moved (it was on tether by the way) and no matter what pwm i set it to nor what port the joystick was on i got nothing from the motor (and the motor does work, and yes everything was powered properly for you wise guys )
So, is it obvious what im doing wrong? It cant be that the controllers are busted, can it?? Any help would be appreciated. Oh, and if i can get this to work, ill return shortly to ask how to get those spikes hooked up to solenoids (meaning, would i have to code in pbasic? or is it qbasic? We'll cross that bridge when we get to it)
Thank You In advance
-LGuY
New robot controller next year? KenWittlief Rumor Mill 94 12-10-2003 21:23
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
team 857 partial 2003 robot ajlapp Robot Showcase 14 27-01-2003 22:30
Robot Controller & Operator Interface troubles patrickrd Technical Discussion 10 25-10-2001 07:36
