Go to Post I know what "finished" means, and I know what "robot" means, but what is this "finished robot" of which you speak? - Rick TYler [more]
Unread 05-04-2004, 18:45
Grommit Grommit is offline
#0115 (Monta Vista Robotics)
Grommit will become famous soon enoughGrommit will become famous soon enough
Send a message via AIM to Grommit
Re: Going over 6 inch step with 12 inch wheels
I'd like to point out that the 12" wheels are actually 12.5" wheels, which makes a slight difference. But more importantly, it requires a very low center of mass to drive one of these things. I watched Kehillah Jewish High School, Team 1043, with Patrick as driver (over two years of experience), in practice, and even he had problems with the robot tipping over. The robot had a large arm mounted upon it to hang, and it wasn't particularly heavy, but consider the following:
Diameter 12.5" implies a maximum wheel base of under 24 inches, probably 20 after the protection in the front. Under these rather optimal conditions, with one wheel up on the step and the other down, we have an angle of nearly 18 degrees. With a center of mass that is high enough, the momentumof the base might flip you over before your other wheel reaches the step.
Unread 05-04-2004, 23:55
Matt Matt is offline
Matt is on a distinguished road
We actually have the 9 inch wheels. We have a belt drive system. When going up the step our belts are being pushed on the plat form and pulling us up the ramp. With this we have the ability to climb the 6 inch step with no power and with no ramming speed.
Unread 10-04-2004, 19:01
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
I don't know if you guys have any type of arm, but thats the key. In NJ, our robot would bounce and bounce and bounce for about 40 seconds until it got up the ramp, and then we had to do it all over again...wasn't pretty. This way was with the hook in the back. Next match we turned the bot around and extended the arm in front of our robot, we were on the top step hanging in 15 seconds...the start of our success.....try it with an arm if not...might i recommend zip ties and pneumatic tubing....
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 10-04-2004, 21:14
Combat Chuck Combat Chuck is offline
Team Role: Scout
Combat Chuck is on a distinguished road
If you guys can get the front wheels on easily and are having trouble with the back wheels, have you considered using a small piston on the back end to lift the rear of the robot enough to clear the platform. If you lift the back of the robot, you can pull the robot forward with the front wheels until the back wheels are on the platform, then retract the piston and continue on.
2004 Peachtree Regional Finalists
2003 GA BEST Champions
Unread 10-04-2004, 21:51
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We also use 16" wheels, and had a little trouble getting up the step. We added some weight to the front (on the bottom) and now have no trouble. A lot of the other suggestions are good too, if you don't have weight to spare.
Unread 10-04-2004, 21:53
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
My team quickly realized that so much can happen on the platforms. (tested out our tread drive subsystem and flipped every time) What I would suggest is add another 2 feet to your arm/hanging mechanism so that you can hang from the floor. We have a light (4 lb) 12' telescoping arm, the extra 2 feet was well worth it for us. I realize this might not be possible, but just tossing another idea out.
Unread 10-04-2004, 22:21
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
for all teams that have problems with turning and the like - in the future, use 6 wheel drive. all your problems will be solved
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 06-04-2004, 20:44
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Originally Posted by Al Skierkiewicz
Joe,
I think if you watched closely, the robot front tires are actually being pushed into the step edge. The resulting force combined with the turning ability of the tire results in the tire climbing the edge. The robot front wheels would climb even if they weren't powered. (Think of a bike going up a curb.) There is just more point friction on the front tires. Lowering the air pressure in the rear tires should help quite a bit. Some teams have added some friction enhancers, i.e. teeth or grippers, to the tires. These grip the edge during climbing and do not allow the tires to slip on the platform edge. I have seen grippers mounted right on the tire and on a wheel attached to the tire.
Thanks for all the replies from everybody.
You Guys are the best.
Joe P
Unread 10-04-2004, 01:11
I have a similar question about the smaller wheels:
We were considering replacing our dysfunctional swerve drive with a wheel setup that might actually give us the mobility to perform on the field. We were wondering if it might be feasible to, at the same time, climb up the steps. So my question is, can we manage to clim the 6 inch step with 8 inch wheels, given that we have a 3 inch foot? I know that theoretically, we should be able to, because with the foot down, the center of our 8 inch wheels are over 7 inches off the ground, and with a little shove, we should be up. I was wondering if anyone actually tested this themselves, as this would help us decide between what replacement we should select.
Shrenik Shah
Engineering Director
Team 115: Monta Vista Robotics
Congratulations to Mr. Shinta for winning Woodie Flowers at Silicon Valley!
Unread 10-04-2004, 01:27
Aaron's Avatar
Aaron Aaron is offline
FRC #3719 (Whaler Robotics)
Aaron is on a distinguished road
Send a message via AIM to Aaron
it's probally a balance problem, we had the same problem until we decided to flip the sticks around and drive the robot backwards. when we got the weight to the front we got up fine
Team 3719 - 2013-Present
2014 RI District Judges Award
Team 1493 - 2007
2007 UTC Connecticut Regional 2nd Seed and Semi- Finalist
Team 11 - 2001-2005
2005 New Jersey Regional Chairmans Award Winners, Palmetto Autodesk Visualization Award Winners, Palmetto Judges Award Winner
2004 Palmetto Regional winners of DiamlerChrysler Team Spirit Award, Palmetto Regional Winners(281, 11, 122), Curie Division 5th seed (11, 190, 179)
2002 J&J MidAtlantic Regional Finalists, Canadian Regional winners of the Xerox Creativity award
Unread 10-04-2004, 18:49
Mel's Avatar
Mel Mel is offline
Retired Scalawag President
#1359 (The Scalawags)
Team Role: Leadership
Mel is on a distinguished road
Send a message via AIM to Mel Send a message via MSN to Mel
My teams robot has 4 16in wheels and we found that putting extra weight on the front helps. Also, we keep them all a little deflated but it took a while to find what the optimum amount of air was. Maybe during practice rounds you could experiment with the pressure a little; make sure to have the same amount on either side or you won't be able to drive straight!
2004 PNW Rookie All-Stars
2004 PNW Highest Rookie Seed (seed #2!)
2004 PNW Imagery Award
wheels, wheels, wheels.... Jesse Control System 1 05-02-2004 15:00
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
