Go to Post [in response to http://www.welovefirst.com/] I feel like I've just been FIRST Rick Rolled. - kramarczyk [more]
Unread 05-04-2004, 21:26
ufa_mike ufa_mike is offline
AKA: Mike Deaves
#0865 (Warp 7)
ufa_mike has a little shameless behaviour in the past
independant 4 wheel drive
I noticed this year that the teams who did well didn't have a very fancy design or anything they had a robot that drove well and had good speed and torque. I thought about it and decided that the best way to maximize traction and driveabiliy is to have all four wheels spinning at the same rate. This means four seperate gearboxes and a shaft encoder on each wheel. Then a program that keeps thmspinning the same speed. I was wondering if anyone else has had any experience with a system like this and if it woked or didn't work ect.
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
