Malicous RC Code?
An interesting thought just occurred to me. I was thinking about the VCU regional, all those microcontrollers with radio links sitting around, and the (obvious?) issue came to mind. Would it be possible for a program to replicate via radio link, perhaps through some clever buffer overflow? I'm guessing the answer is no, but it's worth looking in to because:
1) It's technically interesting ![]() 2) You'd want to patch that before someone else has a similar thought ![]() NOTE: Yes, I know this would be horrible, I don't advocate this kind of thing. Yada, Yada, Yada... Last edited by phrontist : 06-04-2004 at 16:57. |
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Interrupt timer, executing code asap? | SeanCassidy | Programming | 10 | 07-03-2004 01:47 |
| Inserting Naviagation code into Default code? | actorindp | Programming | 3 | 28-01-2004 18:12 |
| Does your team use the Default code. | Jeff McCune | General Forum | 2 | 09-01-2003 14:46 |
