Go to Post What if, each alliance has a pile of AndyMark equipment in front of them. They then have 2:00 minutes to assemble said equipment, and build a working robot that will race to the other side and grab the other alliance's flag. - Pjohn1959 [more]
Unread 06-04-2004, 17:47
psychoCHIPMUNKK's Avatar
psychoCHIPMUNKK psychoCHIPMUNKK is offline
Technical Manager
#0241 (Last Minute Fix)
Team Role: Driver
psychoCHIPMUNKK has a little shameless behaviour in the past
Send a message via AIM to psychoCHIPMUNKK Send a message via Yahoo to psychoCHIPMUNKK
Question Atwood Speed help
I知 planning on using an Atwood in an Inventor model that I知 doing for my engineering class and I came across a question; The spec sheets have "Normal load" in the performance chart, but what is normal load? is it weight specifically for this motor, or is there a standard load, say 150 lbs the motors are tested on? Any help would be greatly appreciated. If it matters, I知 trying to figure out the RPMs under different loads to calculate how fast it can move.
Team 241
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Limit of the atwood motors? Clanat Motors 6 16-03-2004 10:46
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Speed of Atwood motors in forward and reverse... Dan 550 Motors 14 04-02-2002 19:55
