Go to Post I would have bought a bigger box of popcorn and sat up higher in the stands. In the middle. - JaneYoung [more]
Unread 23-02-2002, 22:26
Rick Gibbs Rick Gibbs is offline
#0145 (T-Rx)
Rick Gibbs is an unknown quantity at this point
Talking T-Rx pictures and capabilities
All team members agree: T-Rx 2002 is the best robot that we've built yet - at least in doing what we designed it to do. Like Joe J. said - whether or not we designed it to do the right thing is another question.
In case anyone puts together a robot database, here's some info to start it off. First, links to some key pictures in the gallery:
http://www.chiefdelphi.com/forums/pi...rrow=4&trows=3
Here's some stats:
Overall Stats
  • 128 lb
  • Low center of gravity
  • Team's 6th year of existence
  • Veteran driver
Drivetrain
  • 4 wheel drive.
  • 1 drill motor powering each side
  • Reliable drill transmission shifting
  • High traction wheels
  • Sorry, I don't have speed specs.
  • ~5.5:1 gear reduction between drill shaft and wheels
Goal grabber 1
(featured in middle link)
  • Can have goal firmly in control within 3 sec from start of match.
  • No alignment needed - just ram goal with grabber extended. Spring loaded latches grab posts.
  • >95% success rate grabbing when ramming goal.
  • Can release goal if needed.
Goal Grabber 2
(Here's where you can tell that I'm being honest)
  • Designed for last minute goal grabbing (from partner?)
  • Can't release goal
  • Can't collect balls with goal attached on this side
Ball Collection
  • Designed to shoot balls into goal when attached to Goal Grabber 1.
  • >80% Success rate.
  • Steel discs mounted on wheels to maintain inertia.
  • Variable speed to adjust for balls with different inflation.
  • 'Rabbit ears' help funnel balls to shooter
Hope you find it useful See you in Philly, New Haven, and hopefully EPCOT!
Rick Gibbs
ROBBE Xtreme (Team 56) 2001 Pictures and Videos... archiver 2001 0 24-06-2002 01:12
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
ROBBE Xtreme 2001 (team 56 pictures) archiver 2001 16 24-06-2002 00:31
