Go to Post "Mother nature does not give partial credit" -Woodie Flowers, Kickoff 2003 - TerryDolan [more]
Unread 13-04-2004, 00:29
Guest
Posts: n/a
Autonomous Competition SDK - Testers needed!
Well, in this thread, I discussed the possibility that Team 948 would host a FIRST-wide autonomous programming competition. So, I've made some progress and this is the first version of an SDK used to compete. Here it is!
What I need is someone to test writing a simple class that extends DefaultRobotCode. What you need to do next is replace the following lines in GraphicView.java
Code:
 SpinRobotCode s1=new SpinRobotCode();
s1.spinDir=0;
with
Code:
 YourRobotCode s1=new YourRobotCode();
where YourRobotCode is the name of the class.
To make your own autonomous code, write code in the RunNextFrame() method of your class. If you have any questions, post here.
Check the next post. Use that ZIP file.
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
