Go to Post You miss 100% of the shots you don't take - Steven Donow [more]
Unread 20-04-2004, 18:08
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Fischer Price Info
A few questions on the FP motor:
1. What is the thread on the mount holes on the FP motor?
2. What is the exact diameter of the output shaft?
3. If anyone has ever pressed on a new pinion, what size hole did you drill into the new pinion for the press fit?
Thanks
Unread 20-04-2004, 19:02
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Re: Fischer Price Info
You might want to consult the cad files of the motor http://www.firstcadlibrary.com/ ... you can get dimensions off of there.
Unread 20-04-2004, 19:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
That might not be the new one, also the dimensions are only as good as the measuring tool and person who took them.
Unread 20-04-2004, 22:18
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
The link below may help out.
I am 99% sure it is the same motor we recived in the kits. It may or may not be the same for previous years models (espically those not made by JE).
http://www.johnsonmotor.com/product_...?ProdID=130--A
-Andy A.
Unread 21-04-2004, 13:49
Ok, thanks guys for the info.
However, the model of the FP motor on FirstCad Lib. doesn't have a tapped hole for the mounts. I'm guessing its a metric thread (the rest of the motor is metric), but does anyone know what it is?
Unread 21-04-2004, 17:36
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
For whatever reason I can't find the drawing I know I have of the Fisher-Price motor, but I do have the data you need. The hole you need to put in the pinion is 0.123" +0.001". The shaft is a nominal .125" shaft with a knurl (rough lines) on it. The dimension and tolerance I gave you is what I have been using since 2001 (the shafts have not changed). The mounting holes are for M3 x 0.4 pitch screws and are 25mm apart centered on the shaft diameter.
I hope this helps.
-Paul
Unread 22-04-2004, 14:08
Exactly what I needed.
Thanks Paul!
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
Fischer Price Motor help needed archiver 2000 10 23-06-2002 22:07
Fischer Price Part Number? bmusser Technical Discussion 0 02-02-2002 12:26
fischer price motors Paul Marshall Motors 4 12-10-2001 09:44
