Go to Post "I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." -Woodie Flowers - Barry Bonzack [more]
Unread 24-04-2004, 23:00
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Mounting the drill motor
As I've seen this done many different ways, I decided to start this thread to discuss the advantages and disadvantages of different methods of attaching the drill motor (without gearbox) to a custom transmission.
My own experience has been interesting. The drill motor mount we used was on MVRT 115’s swivel drive this year. Made from 3/4 inch solid Lexan, the drill motor is pressed in, and pins in the Lexan that go into the holes in the front of the drill motor to keep it from rotating. Not that it would, it was quite a snug press. Then, this Lexan “adapter” was screwed onto the swivel drive, making it actually really quick and easy to replace drill motors, provided you had a press (we used a vice).
All in all it was a good idea, nice and light, easy to maintain, never really failed. However, under unknown circumstances to me, one of these Lexan pieces broke. I highly doubt it was from running the motor, because it broke in the pits. Anyway, we had aluminum replacements, so we popped those on. Personally, I feel that these Lexan things were really good for their weight and size.
However, as I said earlier, this thread is for discussion of different methods, so end of my blabbing.
But… here’s how I’ve seen or think it could be done:
1. Thing that goes around it, screws down to clamp onto the motor
2. Sheet metal screws. Big ones.
3. Rivets that go into the holes on the motor
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
