Go to Post It's not easy dealing with the reality that others aren't as passionate as we are and that the process may be slower than we want it to be - but it gives me plenty of time to think and prepare. - JaneYoung [more]
Unread 26-04-2004, 15:53
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: Multiple Auton's
Originally Posted by Joe Clohessy
I was wondering of a way to do multiple auton modes. Please if you have any proven information let me know either in a PM or Email DragonMan@si.rr.com .
Can someone tell me why this theory wouldnt work ??
Does anyone have an auton mode that has a switch to change between modes that I can look at and pick apart. Thankyou
Joe, your theory should work just fine. We also used switches to customize our autonomous mode. We could use switches to determine which side of the field we started on, what path to drive, and whether to do it in high gear or low gear. It was all configurable on the field, so our autonomous mode selection was a match-time decision, often based on who was lined up opposite from us.
The code is pretty much what you have above, albeit much uglier. This is an earlier copy that wasn't cleaned up.
Cheers!
Code:
void User_Autonomous_Code(void)
	static unsigned int auton_status = 0;
	static unsigned char left_set; // left motor speed set-point
	static unsigned char right_set; // right motor speed set-point
	static unsigned int counter; // used to take snapshot of clock for dead-reckoning moves
	unsigned int pressure;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
		relay2_fwd=1; //turns brake off.....
		if (Clock > Old_Clock) // Old_Clock and Clock are serviced by the IR Timer - this line ensures a new IR cycle has occured
			Old_Clock = Clock;
			switch (auton_status)
				case 0:
					Left_Encoder_Count = 0;
					counter = Clock;
					left_set = 127;
					right_set = 127;
					relay2_fwd = 1;
					if (rc_dig_in10)
						relay5_fwd=1;
					else
						relay5_fwd=0;
					auton_status++;
					break;
			case 1:
		if (rc_dig_in11)
			if ((Clock - counter) < 384) //this stops the robot in low gear right in front of the goal
						left_set = 255;
						right_set = 225;//fudge factor
					else
						left_set = 127;
						right_set = 127;
					    counter = Clock;
					break;
		if (rc_dig_in12)
			if ((Clock - counter) < 460) //this makes the robot hit the goal and go straight 3/4 of the way
						left_set = 255;
					else
						left_set = 127;
						right_set = 127;
						counter = Clock;
					break;
		if (rc_dig_in13)
				if ((Clock - counter) < 576) // rush down to the other end of the feild hitting the goal HIGH GEAR
						left_set = 255;
						right_set = 255;
					else
						left_set = 127;
						right_set = 127;
						counter = Clock;
					break;
		if (rc_dig_in14)
				if ((Clock - counter) < 396) //stop beside the mobile goal,
						left_set = 225;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
					   	counter = Clock;
						auton_status=2;
					break;
				case 2:
				if ((Clock - counter) < 15) //turn to face right back at you.
						left_set = 0;
						right_set = 255;
					else
						left_set = 127;
						right_set = 127;
					   	counter = Clock;
						auton_status=3;
					break;
				case 3:
				if ((Clock - counter) < 10) //positions itself behind the goal
						left_set = 255;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
						counter = Clock;
						auton_status=4;
					break;
				case 4:
				if ((Clock - counter) < 15) //positions itself behind the goal
						left_set = 0;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
					    	counter = Clock;
						auton_status=5;
					break;
				case 5:
				if ((Clock - counter) < 384) //positions itself behind the goal
						left_set = 255;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
					    	counter = Clock;
					break;
		// Carol's cubic transfer function that desensitizes small movements, but still allows full speed
		temp_p1_y = (signed long)left_set - 128;
	    pwm01 = (unsigned char)(((temp_p1_y * temp_p1_y * temp_p1_y)  >> 14) + 128);
  		temp_p2_y = (signed long)right_set - 128;
  		pwm02 = (unsigned char)(((temp_p2_y * temp_p2_y * temp_p2_y)  >> 14) + 128);
// Run compressor
		  pressure = Get_Analog_Value(rc_ana_in16);
		  if (pressure < 800)
		  	relay6_fwd = 1;
		  else if (pressure > 925)
		  	relay6_fwd = 0;
		// Get all 6 drive motors working together
		pwm03 = pwm01;
  		pwm05 = pwm01;
  		pwm04 = pwm02;
  		pwm06 = pwm02;
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Unread 26-04-2004, 17:25
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Here are two ways teams I helped accomplished it this year.
1) Use a BCD style rotary switch available from Digi-Key (hooked to digital input pins 15-18 in this case). 16 choices using 4 digital input pins or 8 choices using 3 pins. The extra selections were used for diagnostic software rather than have so many autonomous programs.
Code:
static unsigned int swtc; //set equal to the switch input
swtc = PORTJ>>4; // Auto select switch 0-15
switch(swtc)
	case 0:
	default:
		AUTO_0();
		break;
	case 1:
		AUTO_1();
		break;
2) Use a regular Radioshack style mechanical rotary switch. In this case a 6-position switch hooked to digital input pins 11-16.
Code:
if (!rc_dig_in11)
	 Auto_1();
else if (!rc_dig_in12)
	 Auto_2();
else
	 Auto_1();
multiple definition error in MCC/Linker (possible bug?) wun Programming 5 01-04-2004 17:49
Multiple programs/autonomous routines galewind Programming 12 09-01-2004 22:25
question for teams created among multiple high schools archiver 2001 20 24-06-2002 03:58
multiple e-mail notifications srawls CD Forum Support 3 23-05-2002 12:55
Multiple Regional Winners and a little jab JamesJones General Forum 32 10-04-2002 23:38
