Go to Post Sure, whining is easier than working, but what's more rewarding? - PayneTrain [more]
Unread 27-04-2004, 02:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
2004 Tecknokats Drive System
Well, after seeing pictures and prints of several of the Technokats' previous drive systems, I eagerly awaited seeing what they would come up with for the 2004 year. While I don't expect prints or a white paper so soon, I am curious as to what it is and what it looks like. Since I haven't been to any of their events, I haven't heard about or seen even the slightest bit of it. So, what is it?
Unread 27-04-2004, 15:58
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: 2004 Tecknokats Drive System
Below is what I can tell you, and I'll leave it up to Baker/whoever to explain it in detail. This should keep the thread from getting pushed down too far without an answer.
I don't really know that much about the specifics on the drive base, but I know a little bit. It was a 4 wheeled drive base with a gearbox on each side just like normal. Each gearbox was powered by an Atwood motor and a Fisher Price motor (atleast that's what it was when i saw it). Both sides were also shift on the fly like normal. The wheels they used looked very similar to those small front wheels that you see on shopping carts.
Here are some pictures that I took on Feb. 21, 2004. They aren't the best, but they show a little. I also don't think the wheels in this picture are the exact ones they used, but I may be wrong.
Front Wheel Close-Up
Robot Right Side View
Close Up Side View
Looking Into Robot From Above
Close Up of Gearbox For Ball Suction
Close Up of Gearboxes
Good Side View of Robot
Another Wheel Close Up
Hopefully, someone who's actually on the team this year can do a little better job than me explaining it for you
Purdue Alumni
Cummins, Inc.
Unread 27-04-2004, 17:18
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
I know they posted a whit page of their gearbox. It's somewhere on here...but I'm sorry that I couldn't find it. It seems to disappear right when you need it.
Unread 27-04-2004, 17:21
Rookie Year: 2000
The one you're thinking of is probably the 2003 Gearbox. The gearbox they designed and used this year was quite a bit different (larger size and different motors).
Purdue Alumni
Cummins, Inc.
Unread 28-04-2004, 08:14
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
If you look closely at the gearbox picture you will see a hose clamp around a cylinder in front of the fisher/drill motor. Andy Baker showed me this really neat sub-assembly. It takes the first reduction out of the drill gearbox and uses it to reduce the fisher or drill motor speed to near CIM motor output. Of course you need to put a drill gear on the fisher motor and there is an adapter to compensate for the difference in motor OD. All in all a very nice design that puts the two motors on the same side.
I think I have this essentially correct and am looking forward for the white paper on this. I can envision all sorts of mechansims that could use this subassembly
Andy Brockway
Team 716, The Who'sCTEKS
Unread 28-04-2004, 16:12
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
I believe it was Joe Johnson from Chief Delphi who was telling a few of my team members and I about a similar assembly though he described using a gearbox from some other larger Bosch drill with three speeds. He said 47 would be releasing a white paper on it, if im not mistaken.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 28-04-2004, 17:05
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
We need to get some good pictures of our switching gearbox and the planetary reducer for the drill and FP. We used it for the FP, but it could be used for the drill (easier, in fact). This stuff will be posted within a few days.
Andy B.
Unread 28-04-2004, 22:19
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Andy B.
Well, just what have you been doing since February 26th?
The build season has been over for weeks.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 23-06-2004, 23:38
Team Role: Teacher
Just curious Andy, any more info/pics on the 2004 Technokat drive? We'd all love to see more.
pic: 2004 drive 930 CD47-Bot Robot Showcase 6 10-02-2004 17:12
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Chassis Material/Construction sanddrag Technical Discussion 51 05-12-2003 12:59
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
