Go to Post These are threads, and they are what hold the community together...so CD must be a threaded fastener right? - Andrew Blair [more]
Unread 29-04-2004, 08:26
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Coding / Style Standards for sharing C code
There is a thread here: http://www.chiefdelphi.com/forums/sh...589#post259589
were a bunch of folks are thinking that it would a good idea to have a place to share code for running FIRST robots.
I started to put this idea on the end of that thread, but I decided it needed its own thread, so here it is.
Before we go too much farther on the idea of an open source movement for FIRST code and/or a code repository, I think it would be wise to putting some thought into a choice of a coding standard/coding style.
By this I mean many things.
Starting with the trivial, like using X spaces as an indent (and NOT tab chacters) and where to put the { after an if statement. But there is more than that to work through.
It would be nice to see some agreement on naming conventions (e.g. constants are all caps with underscores between words THIS_IS_A_CONSTANT, variables begin with a noncap and use caps between words thisIsAVariable -- this are just examples, I am not actually proposing this as a standard).
Beyond this there are some even higher level things that we can agree on that will save us a lot of hassle when we try to integrate code from many source (e.g. we may decide not to allow using nested macro definitions or we may try to encourage use of enum to define constants rather than macros or maybe we can agree on a something as simple as where to put [] in macro definitions to keep from generating subtle math errors). Another idea is we may all want to use the same lint-type program before publishing the code.
Anyway, my point is there is a lot of ways we can make this library easier to understand, use and improve if we can get some agreement on a set of standards and/or a coding style before we get too many things into the library.
I am not the right person to lead this but I know there are a lot of good coders out there with a lot of good experience with this type of thing. Is there someone or some small group of someones willing to take this on?
It would be a great service to the FIRST coding community.
Think about it.
Joe J.
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
style srawls Programming 19 23-05-2002 17:02
