bearing help
http://www.sdp-si.com/eStore/CoverPg/Bearings.htm
I'd thought a bearing was a bearing, but it looks like i'm sorely mistaken, and I hate to think i'm missing out. Ball bearings, linear ball bearings, needle roller bearings, thrust bearings, pressure bearings, press bearings, sleave bearings. I think I grasp most of the distinctions, but in terms of FIRST what are the part/application relationships? Specifically, which of these are useful for a press-fit in a gearbox? Which of these make sense to use inside the free-gears of a dog-shifting system? Are some of these not viable with a keyed shaft (needle rollers?). Which can handle our driving loads? Which can handle side loads as per swerve module needs? Thanks all. |
| 5/8 keyed shaft trouble | dddriveman | Technical Discussion | 14 | 18-05-2004 09:49 |
| pic: Swerve^2 Prototype | CD47-Bot | Robot Showcase | 24 | 23-01-2004 12:11 |
| Bushing v. Bearing | VinceT | Technical Discussion | 14 | 22-12-2003 19:11 |
| Need A 0.75" ID bearing .DWG | Tytus Gerrish | Inventor | 6 | 22-10-2003 11:23 |
| Bearing support - Official | Mike Martus | OCCRA | 0 | 24-09-2002 05:26 |
