Go to Post What I’m trying to say is that you should not necessarily be looking to build the next “cool” thing, unless that’s your team’s goal and you’ve got the resources to finish it by ship date. - Bill Gold [more]
Unread 02-05-2004, 14:48
omega's Avatar
omega omega is offline
omega is an unknown quantity at this point
Question window
does anyone here know any good code for programing a window in c++
similar to the defalt window for vb
Unread 02-05-2004, 14:58
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: window
Try on Google. There should be tons out there. Maybe you'd just have strip some extra stuff off.
Unread 02-05-2004, 16:08
omega's Avatar
Re: window
ok thz ill try it
Unread 02-05-2004, 16:46
Programming User
Re: window
ok thz ill try it
If you can't, I'll give it a try.
Unread 03-05-2004, 03:24
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Re: window
Well, it really depends on what you want this window to do. The most basic Windows program that creates a dialog box would just be something like this:
Code:
#include <windows.h>
int WINAPI WinMain(HINSTANCE hInst, HINSTANCE hPrev, PSTR szCmd, int iShow){
   MessageBox(NULL, "Hello, World!", "Simple Dialog", MB_OK);
If you want to do more complicated stuff, email/PM me and I can hook you up with some examples. Also, take a look at RoboGUI, which you can find at www.robbayer.com, as it contains a bunch of Windows code. If you're interseted in MFC, take a look at RoboEmu too.
-Rob
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 03-05-2004, 07:35
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: window
If you are using MSC++ 6.0, the 'Dialog' resources are what you're looking for. Either that or do it all in code.
If your using .NET, haven't a clue.
Unread 09-05-2004, 11:11
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Re: window
Forget about old-fashioned C-style Windows apps... too hard to create/manage.
Use MFC C++ projects for MSC++6 or .NET.
If you're using .NET 2002, use MFC. If you're using .NET 2003, you can try SWF (System.Windows.Form), aka Managed Windows Forms to write C#-style code. Note that managed code will only run on the .NET Framework.
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Help with window motor HWRobotics Motors 15 11-02-2004 02:43
window motor connection albertgates General Forum 1 12-02-2003 17:18
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
Re: window motors archiver 1999 1 23-06-2002 21:56
