Re: Tank Treads
SO to my point i agree with you cory. -Pat |
Re: Tank Treads
We just use different traction. There are four kinds. Slicks, Red Slicks (Not thick red on the track), Thick Red (Thick red on the track) and Green (The most traction you will ever need). Last year was good for the thick read. Did not mess them up. Once we tore one it sliced the red slick to peaces. This year the thick red was awsome! Great on the surface to climb! My adivise. Dont go with the Green unless you have the solid center. Go with either the Slick Red ones or the Thick Red ones. Having a pair of just slicks is a good a idea for emergencrys. Check out our web site at. www.valleytech.k12.ma.us/robotics |
Re: Tank Treads
Re: Tank Treads
Team 61 has used tracks for 10 years. We also use Brecoflex belts. We have modified it little bit every year. First slicks. Then with traction and a center wheel. Then we had to increase our shafts from 1/2inch to 1inch. We have lots and lots of power and traction. Below are some pictures.
Early Tracks. No Center grove = bad.. kept throwing the belts http://www.valleytech.k12.ma.us/robo.../Robot1996.jpg Slicks. They have a center grove but they have no traction. Still use them till this day for testing. http://www.valleytech.k12.ma.us/robo...res/Robot6.jpg and from this year testing http://www.valleytech.k12.ma.us/robo...2004track1.JPG These are the green tracks. man do they have so much traction. They bent a lot of shafts http://www.valleytech.k12.ma.us/robo...2%20Monday.jpg and http://www.valleytech.k12.ma.us/robo...2002Track1.jpg and http://www.valleytech.k12.ma.us/robo...02%20Track.jpg This is the bad part of haveing a lot of power and a lot of traction http://www.valleytech.k12.ma.us/robo...s/MVC-673S.JPG and http://www.valleytech.k12.ma.us/robo...s/MVC-671S.JPG Even with the Red tracks. Less traction but still a lot http://www.valleytech.k12.ma.us/robo...rokenTrack.JPG Advantages to have tracks http://www.valleytech.k12.ma.us/robo...%20T59%20A.jpg and http://www.valleytech.k12.ma.us/robo...ng%20Robot.jpg and you can give good piggy back rides http://www.valleytech.k12.ma.us/robo...OHBuzzonUs.JPG All pictures of our robot can be found at http://www.valleytech.k12.ma.us/robotics/ Check out this years build season and see how it all started! |
Re: Tank Treads
these threads should help when choosing treads vs wheels
http://www.chiefdelphi.com/forums/sh...ht=tank+treads http://www.chiefdelphi.com/forums/sh...ht=tank+treads also if you are searching google for distributers...try searching for timing belts |
Re: Tank Treads
1024 used treads from brecoflex for the past two year.
the picture is of this years tread: http://www.chiefdelphi.com/forums/sh...ad.php?t=25346 as for turning on carpet the center metal pulley is lower creating a bow in the tread allowing us to turn on a dime. |
Re: Tank Treads
Team 1097 has used treads since the forming of our team. Our origional treads were from a snowblower donated to us from Tahoe Sports and Motor. This year we used this website listed somewhere in the chiefdelphi discussion above: http://www.robotcombat.com/store_tanktreads.html They were basically modified forms of snowblower treads that you could buy seperately from the snowblower. We then machined some of the parts down for use on our bot. We ran out of time to machine the cogs, which would have been nice, since they were expensive. Just to give you an alternate option to Breco, which can be expensive. I think this entire year we were pushed once, maybe twice, and the treads have always been a major benefit for defensive strategies.
Re: Tank Treads
Side note: We didnt lower the idler(middle wheel). What we did was just use a larger wheel so it offset each of the two drive cogs sorta like this O O O Okay its upside down but you get the point. |
Re: Tank Treads
234 used treads on our 2004 robot that were specifically made for climbing stairs and for great traction. The most unique feature is the 24mm pitch...they are some of the most aggressive treads around! We were very pleased and they were easy to work with. For pictures and ordering info: http://www.thistle.uk.com/stairclimbing.html
#10
Re: Tank Treads
1141 used a pair of old snowblower treads for our first year. They didn't give us a huge amount of traction, mainly because our drill motors were unscrewing themselves from our drivetrain, and if we tried to push, we'd put ourselves out for the match. If you're looking for the cheap direction to go, they cost us a trip to the dump.
| Swerve/crab drive and tank turning | activemx | Technical Discussion | 9 | 23-02-2004 18:26 |
| tank treads vs. threaded wheels | lj8758 | Technical Discussion | 14 | 24-01-2003 00:30 |
| Under or Over? To tank or Not to tank that tis the question! | archiver | 2001 | 2 | 23-06-2002 22:53 |
| TANK TREADS...welp. | archiver | 2001 | 13 | 23-06-2002 22:50 |
| What problems have you encountered using treads? | M.I. | Technical Discussion | 8 | 15-01-2002 22:13 |
