Go to Post "In PID, Integrals are like diamonds. They are forever!" - Sam390250 [more]
Unread 05-05-2004, 17:06
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
A Quick Question
I'm doing a school project with robotics...and am programming my robot right now with one of the old PBASIC controllers and operator interfaces. The problem I have is that I'm not sure what port on the old operator interface is used to import the program. None are speciffically labeled. Is it the Radio, or Dashboard (the only 2 it could be)....I'm assuming it's dashboard.
Well...I seem to be getting some response from the dashboard...but now I'm having trouble figuring out how to get the programmer into the operator interface. I'm just using the edu robot base code...and the Stamp Editor program. If anyone could IM me, or post on how I can do this...that would be appreciated.
--I'm using the old edu robot controller.....before anyone makes any comments to that effect.
Unread 05-05-2004, 17:14
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: A Quick Question
The only user-programmable component of the IFI control system is the RC (Robot Controller), in this case you're using the EduRC. The OI isn't user-programmable. There's a port labeled "Program," or "Programming" on the FRC RCs, and on the EduRC, you'll need to flip a switch to indicate whether the DB9 port is used for either "Programming" or "Tether."
Check out IFI's Legacy Documentation for more information.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 05-05-2004, 17:16
Ryan F.'s Avatar
Okay..thanks a lot...again. That is probably my problem. I'm going to try it out on the edu controller now. This is what happens when a mechanical person tries to work with programming stuff .
Unread 05-05-2004, 17:17
Steve Shade Steve Shade is online now
Rookie Year: 1999
Steve Shade has much to be proud ofSteve Shade has much to be proud ofSteve Shade has much to be proud ofSteve Shade has much to be proud ofSteve Shade has much to be proud ofSteve Shade has much to be proud ofSteve Shade has much to be proud ofSteve Shade has much to be proud ofSteve Shade has much to be proud of
You do not program the OI. The OI's main purpose in life is to pass data between the user and the RC. You need to program the RC (Either full size or EDU Controller) through the program port on the RC. To download the code select Run under the Run menu of the the BASIC Stamp Editor.
Legacy documentation on the 2000-2003 system is here
Hope this helps.
Steve
Quick question, probably asked a thousand times... Sparks333 Electrical 23 13-12-2004 20:08
A quick IR sensor question PBoss Programming 7 28-03-2004 21:02
Quick question about the ramp archiver 2001 5 23-06-2002 22:45
a quick question mike pawlak Championship Event 6 02-05-2002 21:15
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
