Go to Post We live for those eureka moments. Whether we win or lose competitions, it's those moments when a student's idea makes something just "click" that will stick with them and influence them to become engineers. - ToddF [more]
Unread 18-05-2004, 14:47
roboteer49 roboteer49 is offline
friend to all!
roboteer49 is on a distinguished road
Lightbulb CHIPS
Ive been thinking about doing a chip only drive system. It appears that the chip has more speed than the drill(5500 to 1000ish) Wouldn't it make more sense to use the chip over the drill. Chips have more torque too I believe. Why do many teams use only drills when chips are more powerful (besides mounting and placing a gear on it.) In terms of power shouldn't u use just chips over drills. thanks
P.S. I know both is better than just one
BAM!
THE THREE LAWS OF ROBOTICS:
1.A robot may not injure a human being or, through inaction, allow a human being to come to harm.
2.A robot must obey orders given it by human beings except where such orders would conflict with the First Law.
3.A robot must protect its own existance as long as such protection does not conflict with the first or second laws.
DEAN-BOT IN 2005
Unread 18-05-2004, 15:14
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Re: CHIPS
BAM!
Well I belive the ships stall before the drills do. So there for i belive the drills have more power. For example. We run drills on one side chips on the other side. We only rip our belts(breco flex timing belts) on the drill side. That makes me belive that the drills are stronger then the chips or that the drills have a higher stall current.
Keep It Simple - Team 61's Motto
Any Thing on out Robot Can be Fixed in 5 Mins!
2005 Motorola Quality Award
2004 Battle Cry 5 @ WPI Eighth Finalists...4th Seed! 6-3 Record! Thx 237 & 830!
2004 Mayhem on the Merrimack Champions! 4th Seed! 9-2 Record! Thx 562 & 1289!
2004 Mayhem on the Merrimack Fastest Robot Award!
2004 Beantown Blitz Champions! 4th Seed! 11-1 Record! Thx 571 & 1100!
2004 National Semi Finalists
2004 Florida Regional Judges Award
2004 Florida Regional Champions! Thx 945 & 386!
Unread 18-05-2004, 16:50
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: CHIPS
I think a lot of teams have used the chips for drive. Part of the problems for some is that they are high rpm while the drills come with the transmission to gear them down. They are geared down to like 1000 and 500 (not exact) from 19000 rpm (again not exact). For teams that don't have the resources to build the chips into their drive the drills are a very nice option. I also thought the drills had more stall torque. It all depends on what you want to do but both work well. I think for many teams the drills are just easier to deal with because it is the easiest to put into a drive straight out of the kit.
Unread 18-05-2004, 16:53
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Re: CHIPS
My assumption all along has been that the chips have more power, but that could be wrong. The reason I think a lot of teams don't use them is the need to build a gearbox for them. Until this year, our team didn't use chips because of that same reason. The drill motors have a simple and reliable gearbox, so if no-one is going to really care/work on the drivetrain, those are the best choice. You could put one of those together in 20 minutes right out of the kit.
Unread 18-05-2004, 16:54
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Team Role: Teacher
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: CHIPS
BAM!
I have to assume that you are referring to the drills with their stock gearboxes. both the drill and the CIM output close to the same power. with its gearbox on, the drill loses some of its power to friction in the gearbox, and is therefore (i believe) slghtly less powerful than the CIM. without its gearbox, it has slightly more power than a CIM. likewise as you said, coming out of the gearbox, the drills have a slower speed, but more torque than a stock CIM. once again if you take the gearboxes off, these numbers are reversed. the CIM is more powerful, yet slower.
the main reason people use drills with their gearboxes is because its alot easier. you don't need much of a reduction coming out of them, and they have two speeds built right in. in addition, they're pretty light.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 18-05-2004, 18:04
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: CHIPS
There seem to be a lot of half-truths floating around here....
While the CIM has up to 346.9 oz-in of torque (2.450 N m), the Bosch has 0.870 N m of torque, and the Johnson F-P has 0.6375 N m of torque, all of these numbers are measured at different rotational speeds. To get a comparable measure of which motor is strongest, you should compare the (mechanical) power of the motors, which equals speed × torque.
At 12 V, the CIM has up to 343 W (0.46 HP) of power, the Bosch has up to 448 W (0.60 HP) of power, and the Johnson F-P has up to 262 W (0.35 HP) of power. Therefore, the Bosch drills are the most powerful, followed by the CIMs, then the F-Ps. (I say "up to", because the maximum power of an electric motor occurs at a single point, in the middle of the power vs. torque curve. Everywhere else, it makes less power.)
Note that these numbers assume that the drill gearbox is not being used.
While the only way to really examine this in detail is to look at the graphs, this should be enough to base your assumptions on.
And if you're wondering, 188 used all of the above motors to drive its robot (all at once, of course).
Unread 18-05-2004, 20:09
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post 2004 Motor Statistics in US Units
To post something very brief... I'm going to get on a bit of a soap box.
Not having information is better than wrong information. I've seen a few people in this post (and other posts recently as well) post things they "believe" to be true.. or that they're "pretty sure about" or this is "close enough to right."
I'm going to correct a bunch of mistakes written here in hopes that we can continue with something worthwhile... I'm just going to tell it how it is, don't be offended.
Here's the stats, all converted to English units, by me a while back.
Code:
Motor Name			Free Speed	Stall Torque	Stall Current	Circuit Breaker	Torque at Breaker Speed at Breaker Power at Breaker
				(RPM)		(in-lbs)	(A)		(A)		(in-lbs)	(RPM)			(HP)
Drill (1)			19,670		7.70		127.0		40		2.18		14190.5			0.491
Drill in High (2)		1,521		48.64		127.0		40		29.27		1041.9			0.484
Drill in Low (3)		450		319.95		127.0		40		103.35		308.3			0.506
Atwood / Chip / CIM (4)		5,342		21.68		114.0		40		7.61		3467.6			0.419
Fisher Price (5)		15,694		3.54		61.0		30		1.74		7980.9			0.220
Globe Motor with Gearbox (6)	104		180.00		18.5		30		180.00		0.0			0.000
Van Door Motor (7)		75		300.88		44		30		205.15		23.9			0.078
Window Motor (8)		86		83.19		24.5		20		67.91		15.7			0.017
(1) - 12 Volts motor curve. Stall specs taken at 40.4 Amps, and assumed linear relationship to approximate at 40 Amps
(2) - Free speed from Gearbox performance, at 11.98 volts. Stall torque estimated at same efficiency as free speed
(3) - Free speed from 2003 manual page 5 reference, stall torque estimated using speed ratio efficiency. No solid available data, hence cause of higher power in Low than possible. Accurate free speed data would help immensely.
(4) - 2004 Motor data from CCL Industrial Motor Limited sheet
(5) - All data taken from 2004 Johnson Electric Manufacturing Specs
(6) - All data taken from 2003 competition specs, adjusted to 12 volts from 10 volts, assuming linear relationship
(7) - All data taken from 2003 competition specs.
Okay, so there are the specs... now to correct/comment on some people's comments.
Stall current isn't related to power.... the max power in an ideal DC motor like the one's we're using is at half the stall (max) torque (and hence half the free speed). Power output = torque x angular velocity. This varies depending on the load to the motor. You often want to design such that you're gearing to get the most power out of your motors.
Something you need to consider is that the max power output of these motors is well beyond the Amp circuit breaker limit. I have already done the calculation at the breaker limit above so that you don't make the mistake trying to design around something that will trip breakers.
Good luck everyone!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 18-05-2004, 21:29
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Re: 2004 Motor Statistics in US Units
Good luck everyone!
Matt
First off, thank you for the concrete data.
Now to pull the thread somewhat off topic.
Taking into account that the breakers have a fair amount of tolernece, in that they can tolerate varing amounts of current for varing amounts of time before opening, perhaps it would be possible to gear a motor for a higher power output then might otherwise be possible if you stuck to a strict amprage budget.
In otherwords, if you knew that the 40 amp breaker takes 30 seconds to trip when passing 60 amps, and the motors duty cycle was perhaps only 20 seconds why not gear the motor to produce peak power at 60 amps rather then limiting your self to 40 amps?
Is there any good data on the trip curves for these new breakrs? I just did a quick search, and didn't turn up anything, although I easily could have missed it. Aslo, is there any data on thier cooling? Any data on how quickly they derate after repeated trips (I noticed this was a major problem for my team this year)?
I guess what I am really asking is for some good data on the 40 amp breakers, and just how much we can push them before we get in trouble.
Anyone have any thoughts?
-Andy A.
Unread 18-05-2004, 22:22
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Post Re: 2004 Motor Statistics in US Units
-Andy A.
The 40 amp breakers trip VERY quickly after 40 Amps. The only data I can verify this with is that from personal experience, noting that at a ratio of 25:12 our machine was tripping against a wall, and at a ratio of 25:10 on the final sprocket reduction, they wouldn't trip... this means that around 20% past thier rating, they trip quickly (5 or 6 seconds). I wouldn't even try messing with these.
The 120 Amp breaker is another story. Dr. Joe and I had a lively discussion on this preseason. He was convinved that those 120 Amp breakers wouldn't trip even throwing boatloads of current through them. We found this to be true. We were running (at peak) somewhere in the range of 160 amps and had no problems.
Until the finals.
In the last round of our last match, after playing in the order of a 10 or more consecutive matches, our main 120 Amp breaker tripped in the finals of Currie, costing us the match, and perhaps much more. These breakers have a thermal element to them, and after back to back matches, they were starting out a bit too warm... and tripped about a minute into the match.
Lesson Learned:
Be sure that you cool your breakers in the finals, as well as your motors.
Matt
Unread 18-05-2004, 22:28
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Rookie Year: 2000
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: CHIPS
BAM!
IMHO chip only drive is the way to go. You get very good power and speed along with a very simple mount(two 10-32 holes). The chip is also a very reliable motor. I rarely hear or people damaging the motor or burning it out(doesn't mean it doesn't happen) where as drills have a tendency to wear out faster and burnout or blow through clutches.
I also am not an advocate for the two motor drive with the electrical system that we are given to work with. It seems to take too much current draw and the robot 'runs out of gas' before the finish. I've formulated this based off my 2003 experience with multiple motor drives.
-Pat
-p.s.: Rmmbr keep it simple stupid
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 18-05-2004, 22:45
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: CHIPS
The cool thing about those 120 amp breakers is because of their thermal element you could cool them and run at higher than 120 for a fair amount of time.
Because 2 of our lead mentors are Electrical Engineers and Thermodynamics engineers they often talked about if they were to put a sort of heat sink near the breaker module itself and were able to cool it, then you might be able to run at high current for a period, we called it like hitting the nas.
This might be beneficial if you are using something like a 6 motor drive in a high torque game.
But to get more on track about the topic. Our team has never used anything but chips on our drive since they were introduced in 2002. The reason being, is the first year soo many teams had problems smoking their drills. The big and beefy chips never had this problem so we tended to use them, then because of familiarity we used them.
Some of the students and mentors did some number crunching on the motors, to come up with a motor efficiency number. I wasn't involved with this as much but I was told that the Chips where the number 1 rated motor for their curve efficiency level. I would have to find out what they used to determine that and get back to you.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 18-05-2004, 23:06
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Post Re: CHIPS
I guess I'll just throw the comment out there that you simply can't be competitive with just one pair of motors and no transmission. You simply won't be able to move fast enough or be able to apply enough pushing force.
On another topic
Efficiency isn't really a concern for these motors. You don't worry about running out of juice in a match, you worry about moving faster and pushing harder than other machines. You want more power out of your motors. I'll take getting .5 HP out at 60% efficiency over .45 HP out at 99%. The batteries are rechargeable!!
Just some thoughts,
Matt
Unread 18-05-2004, 23:13
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
Re: CHIPS
The chips are good motors with the proper gearbox. I like the drills becuase they are practical for a drive system. The only problem with them is the mechanical error in the stock gearbox. It rotates faster going forward then in reverse. We had that problem but you can fix that in programming. And yes the best way to use both those motors is to actually use both the motors.
Student: Team 22
Mentor: Team 4
Unread 18-05-2004, 23:17
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Post Re: CHIPS
From my understanding, this has nothing to do with the gearbox itself, it has to do with the internal motor windings. The gearbox functions the same backwards as forwards, so there shouldn't be any gearing differences that would cause the difference in speeds.
Matt
  #15   Spotlight this post!
Unread 18-05-2004, 23:50
RogerR's Avatar
AKA: Roger Riquelme
Team Role: Teacher
Re: CHIPS
...it has to do with the internal motor windings...
sorry about the double post...
this is the second time that i've seen these 'windings' mentioned, and while i think i know what they are, i'm not sure, and i am curious about what is done to them that makes them cause this. does anyone have a (relatively) simple explanation they can give me?
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
drills and chips Ben.V.293 Technical Discussion 1 07-11-2003 13:11
2003 Drills and Chips Chris Motors 3 12-10-2003 19:02
Counter chips Ryan Meador Programming 9 15-02-2003 00:07
Voodoo Gyro Chips... Ghetto_Child Technical Discussion 3 01-02-2002 16:39
