Go to Post Remember, there are many differents path to obtaining knowledge. There's no need to pigeonhole the process. - Karthik [more]
  #31   Spotlight this post!
Unread 21-05-2004, 00:46
roboteer49 roboteer49 is offline
friend to all!
roboteer49 is on a distinguished road
Re: CHIPS
thanks everyone
after reading all ur responses i realized that chips running at 9ft/sec will be destroyed in the matches.(fast but no torque) Even though I want to stay away from drill gearboxes ive decided to give them another chance. Here's what im thinking. drill in high and chip connected to a output shaft inbetween them, a 3.5:1 ratio between the drill and chip but the gear on the output will be larger(haven't determined the size yet) Also i was thinking about chain and sprockets and then my dad suggested belts, what do u think, anyone ever used belts in a gearbox?
it will look kinda like this ( o0o )
if that makes sense, drill and chip on outside,output in middle . so what if its crude picture.
THE THREE LAWS OF ROBOTICS:
1.A robot may not injure a human being or, through inaction, allow a human being to come to harm.
2.A robot must obey orders given it by human beings except where such orders would conflict with the First Law.
3.A robot must protect its own existance as long as such protection does not conflict with the first or second laws.
DEAN-BOT IN 2005
  #32   Spotlight this post!
Unread 21-05-2004, 01:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: CHIPS
If anyone wants to see the inside of the Chia there are a couple pics here http://team696.org/forum/category.php?cid=5&page=3
For a simple drill-chia drivetrain I would recommend something like this http://team696.org/forum/image.php?iid=166
another pic http://team696.org/forum/image.php?iid=164
It uses the drill in high gear
If you are using large wheels, or don't have room for a large final reduction and would like to run the drills in low with the Chias (or just the Chias by themselves), I would recommend the team 716 2003 single speed gearbox (found in the whitepapers) Team 980 and 696 used it this year with great success. It is a little more complicated to build than the pics I linked to above but it is very reliable, small, efficient and lighter. It has a nice slow output speed of 460 rpm.
Attatched is a pic of ours.
  #33   Spotlight this post!
Unread 21-05-2004, 09:56
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
Re: CHIPS
since chips come to a rolling stop, they make a robot much harder to drive than a drill motor robot
  #34   Spotlight this post!
Unread 21-05-2004, 11:03
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
Re: CHIPS
I agree with most of what has been said in this thread, but there is one major difference between the Chips and drills that I have not seen mentioned thus far.
The Drills are air cooled motors, cooled by a fan in the back of the motor near the brushes. Since it is air cooled, it will continue to give full power when it heats up, and after it stalls, untill it burns up.
The Chips, on the other hand, are not air cooled. They have a variable resistor (a brass colored plate) in the motor so that as the motor heats up, the resistance increases in the plate, giving the motor less current so that it wont burn itself up. Basicly, as motor heats up, its power output decreases. While this helps greatly with durability of the motor, it hurts in an application such as what we are using them for. If you get in a pushing match and you stall your motors for a 2nd or two, the Chips will heat up, and put out less power for the rest of the match. Do this a a couple times, and you will definately notice the power loss. On our 2003 robot, we had 4 motor drive, with the chips powering the rear wheels and the drills in the front. Due to our weight distribution, our rear wheels had the most traction, so the Chips were mostly responsible for turning. Many times when we got to the end of a match, the robot would have difficulty turining because the chips got hot and therefore their power output was cut accordingly.
Just another thing to think about. Oh yeah...did I mention that those suckers are HEAVY.
  #35   Spotlight this post!
Unread 21-05-2004, 11:09
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: CHIPS
Any motor will do that if you set the speed controller to Coast mode and have a high efficiency gearbox with it. Typically when a team uses the Bosch with its stock gearbox, the drive has lower efficiency than the Atwood does when you make a simple 2 reduction gearbox for it. The lower efficiency causes energy and momentum to be lost faster, which you probably had with your Bosch experiences. Either motor can be incorporated into a high efficiency gearbox and give you plenty of rolling after the power is cut off.
[edit] In further reading of your post, it appears you like the quick stopping feature of the Bosch as opposed to the higher efficiency of the Atwood. High efficiency is always good in your drive. You can create the same stopping effect with the Atwoods by switching the speed controller into Brake mode. [/edit]
Follow me on twitter @roboticsrob and my FTC team @griffins10092
  #36   Spotlight this post!
Unread 21-05-2004, 12:18
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Rookie Year: 2000
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: CHIPS
Ok lets recap this alittle.
Drills give more power for a longer period of time under stress BUT will burnout
variable speed with gearbox..high rpm without
CIMs dont burn out very easily...or in some cases at all...are more power efficient and are high RPM.
So I guess this means you have to make deicisions. Do you want to risk possibly burning out your drill motors? Or would you rather risk losing some power with the atwoods?
For my team we would rather risk losing some power from the atwoods..
OOO...let me share something with everyone. Last year at river rage we slapped together a new robot to test our new tranny. at one point we lost one cim due to wiring errors and burnt out the last of our drills cept for one(it was a two motor drive) Coincidently the two motors were on oppisite sides of the robot. It drive great with the two motors opposite of each other...had great power and drove the straightest it had all day.
-Thought I'd share...
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
drills and chips Ben.V.293 Technical Discussion 1 07-11-2003 13:11
2003 Drills and Chips Chris Motors 3 12-10-2003 19:02
Counter chips Ryan Meador Programming 9 15-02-2003 00:07
Voodoo Gyro Chips... Ghetto_Child Technical Discussion 3 01-02-2002 16:39
